Transfer Case Swap Info NP249->NP231 & NP242 - Page 121 - JeepForum.com
 12Likes
post #1801 of 3412 Old 10-28-2013, 06:13 PM
OverlandZJ
Originally Posted by smccloud View Post
My 249 is internal
But you asked about a 242..
OverlandZJ is offline
post #1802 of 3412 Old 10-28-2013, 06:24 PM
smccloud
True, I did. What are the odds I will have to shorten my driveshaft?
smccloud is offline
post #1803 of 3412 Old 10-28-2013, 06:57 PM
Muzramp
Higher than not needing too.
Muzramp is offline
post #1804 of 3412 Old 10-28-2013, 08:41 PM
Platinum5nine
Only one way to find out. I have done 2 so far and neither had to be shortened.
Platinum 5.9 2.25" engine pipes 3" Magnaflow cat, 3" Hooker Aerochamber, 3" tail pipe, Ported kegger, 52MM Throttle Body, 24lb injectors, K&N drop in filter, Cast JEEP valve covers, MSD coil and wires, All new 6 piece clear light kit, 255/65/16 General Grabber HTS, 242 conversion, XJ u-joint front axle shafts
Platinum5nine is offline
post #1805 of 3412 Old 11-01-2013, 12:06 PM
iann32
Ok so I've been searching and trying to get as much info on the swap to the 242 that I could and I was wondering if anybody can help me out. First off I have a 95 zj limiyed with the v8 and 46rh tranny, the build date on my 249 tc is early 94 so it should have the early style gear cut. My question is would I have the 1.55 input shaft or is the .84? Also, whould I need the rear drive shaft fron the donor vehicle?
Thanks,
Ian
iann32 is offline
post #1806 of 3412 Old 11-02-2013, 08:49 AM
zarnold
Thanks,
Ian
You will have the 1.55 input. The donor driveshaft will most probably be to short, while the one you have will be to long. This varies a little, and you may not have to shorten your drive shaft, but the odds are against you here. If you can get the donor driveshaft for a good deal you can use it to test the tc, but I would not use it for anything but that.
zarnold is offline
post #1807 of 3412 Old 11-02-2013, 01:35 PM
iann32
Ok thanks. I also just found this link. http://www.drivetrain.com/parts_cata...arts/jeep.html
According to this the 93 zj has 242 with the 1.55 So should that just drop right in?
iann32 is offline
post #1808 of 3412 Old 11-02-2013, 03:15 PM
comptiger5000
93 ZJ with a 5.2 would have a 1.55" input, 4.0 should be a .84" input (with collar, I think), 4.0 / AW4 combo might be a .75".
comptiger5000 is offline
post #1809 of 3412 Old 11-02-2013, 04:07 PM
iann32
Ok thanks looks like ill just grab an older 242 and hope for the best amd probably swap inputs. Ill atleast have plenty of time to do it being how I'm planning to get and rebuild it over the winter and install during the spring.
iann32 is offline
post #1810 of 3412 Old 11-14-2013, 02:12 PM
iann32
Ok so I decided to go with a 231 and found one for 60 bucks. It has a 95 build date and is from a zj but mine in my zj has an early 94 date . My questionis does anyone know if that will just drop in or am I going to have to build a hybrid case due to different input shaft lengths and gear cut? I'm going to get the case regardless because i can just turn around and sell it.
iann32 is offline
post #1811 of 3412 Old 11-14-2013, 02:40 PM
OverlandZJ
Doesn't appear that way.. taken from first post:
93-95 V8 ZJ's: 46RH transmission, 1.55" 23 spline input shaft
93-95 I6 ZJ's with the 42RE: .840" 23 spline input (with collar)
You have a 5.2 if your details are correct, and as far as I know the 231 was only available in a 4.0L ZJ.
You also cant build a "hybrid" case, that's considered the 249/242 method where they share the same front case half. The 231 case half doesn't swap..
Now, do some research and see if there was a 231 in something with a 1.55" input. Then you could mix parts to get around the gearcut/input issue.
post #1812 of 3412 Old 11-14-2013, 03:04 PM
iann32
Ok. Thanks for the info. Wasnt sure if you could build a hybrid with only the 242 but now I know. My search continues
iann32 is offline
post #1813 of 3412 Old 11-14-2013, 04:26 PM
Dekronic03
Ok so I've been reading a lot of different post and my conclusion is that as long as I find a TC the same year and engine it should be a direct fit? I have a 93 ZJ 4.0 AW4 with a NP249 and it just won't stay in 4hi so I want to swap it out and would only have a day since it's my dd. I found a ZJ the same year with a NP242 but it's a 5.2 would it still be a direct fit?
Dekronic03 is offline
post #1814 of 3412 Old 11-15-2013, 04:02 AM
ejschultz
ejschultz's Avatar
Assuming the PO did the swap correctly, he would have had to get that 242 from a 96-98 ZJ so it'd have the correct in put length. If that's the case, no. It's not going to be a direct fit. You'd have to swap the inputs.
01 TJ - 4.0L, NV3550, 2" Skyjacker budget boost, Xenon flat flares, Trail Gear front bumper, Tuff Stuff rear bumper, RH4X4 sliders, 33" STT Pros on 15x8s
ejschultz is offline
post #1815 of 3412 Old 11-16-2013, 04:35 PM
iann32
Would anyone know if this would be a long input shaft?
http://m.ebay.com/itm/181261310190
iann32 is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
