Transfer Case Swap Info NP249->NP231 & NP242 - Page 12 - JeepForum.com
 9Likes
post #166 of 3312 Old 10-13-2010, 11:48 AM Thread Starter
JrMechanic
Originally Posted by Virmagicus View Post
It's nice when the bolts back right out. I had issues on two different ZJ's where the bolts just spin & had to grind the heads off.
For the cross member? This is true, sometimes they seize into the nut inserts and end up breaking them out. If they look at all rusty it's a good idea to do a few cycles of heat and PB blaster, and preferably an impact to break them loose.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #167 of 3312 Old 10-13-2010, 12:32 PM
rogo
i didnt like the looks of the 4 rusty bolts. my zj had to get my girl to work the next am. i agree the cross member is easer.
rogo is offline
post #168 of 3312 Old 10-13-2010, 01:40 PM
Virmagicus
Virmagicus's Avatar
Yep, the cross member. ^^ Do this if they seem like they won't budge.
Jeff
Virmagicus is offline
post #169 of 3312 Old 10-15-2010, 12:33 AM
Mike48
$99 ?? Oh man, yer killin me... I'm in So Cal.. Orange County to be specific.. I have not done a lot of looking yet, but a yard my Jeep mechanic recommended wanted $500 ! What's the secret to finding a yard for jeep parts ? Google ? I'm hoping you might have an inside line on junk/wrecking yards for ZJ t/c's ? My 249 needs to be replaced, and your post is just what the doctor ordered.. I just need to get my hands on the replacement 242 and not break the bank in the process...
Mike48 is offline
post #170 of 3312 Old 10-24-2010, 11:44 PM
PlatinumNiner
Ebay is your Jeep junkyard. No yards are just Jeep. It would be nice though lol. Most yards also crush trucks as old as ours. Not worth anything to them. They would rather keep newer inventory.
PlatinumNiner is offline
post #171 of 3312 Old 10-25-2010, 11:37 AM
gotricebih
Will a 231 out of a 94 zj 5 speed be a direct swap for my 94 zj auto with a 249?
Or will I have to swap the input shafts?
gotricebih is offline
post #172 of 3312 Old 10-25-2010, 02:55 PM
AlphaLorde
Depends on if you have a v8 or not
V8 yes I6 most likely not but the only way to check is to measure
Look at production dates on the case if you have a late 94 get a late 94 or newer. If you have early 94 get early 94 or older.
They changed the pitch of the teeth on the input some time around 94 when the company changed hands. the input will swap but the teeth will wear then the case will go boom.
ex. I have a 94 truck which was made in Dec 93. I got a case from a 94 zj that the case was built in 92
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #173 of 3312 Old 10-25-2010, 05:27 PM
gotricebih
The case is my 94 zj has a serial# 3 12 93 2. So the build date is 3/12/93 right?
So therefore i would want a case that has a build date pre 94.5?
post #174 of 3312 Old 10-25-2010, 08:36 PM
Syco
Sooooo, did anyone make any progress on going from a 3(4?) prong VIC sender plug from the TC to the 2 prong one on the 242's? I realise it's not *needed* but have a naggleing feeling it's not all done until I get the VIC working
Syco is offline
post #175 of 3312 Old 11-02-2010, 12:17 AM
Mikedc3
This is a great thread. Thanks to all!!!
I have a few questions. I have a 98 5.9 and want to do a 242 swap. I also want to replace the front C/V drive shaft with a U-Joint shaft.
If I get the T-Case, rear shaft, and front shaft from a 96-98 4.0 select-trac as well as the yoke off the front axle, Will I be able to replace my C/V front shaft with the U-Joint shaft? Will everything fit? I haven't seen an answer to this while searching.
Thanks,
Mike D.
Mikedc3 is offline
post #176 of 3312 Old 11-02-2010, 07:39 PM
PlatinumNiner
Thanks,
Mike D.
Not quite. Yes the t-case will work, the front shaft should work, but the rear wont. You re use your stock rear shaft. They used bigger u-joints in the rear shaft on the 5.9
post #177 of 3312 Old 11-03-2010, 09:08 PM
tonyp6796
im having trouble with my 249 to 231 swap. When shifting into 2wd the linkage is hitting on the pivot point not leting it go into gear all the way. Is there a different linkage rod i should use that is shorter of do i have to modify mine?
1996 zj 5.2, 7" IRO LA's, IRO OTK steering, 8.8 rear end, 33 bfg km2's, 231 TC.
tonyp6796 is offline
post #178 of 3312 Old 11-03-2010, 09:58 PM
lonecountryboy
I just did my 249 to 231 swap and it was a direct swap, no problems on the linkage. Did you use the tab off the 231? If you didn't you need to otherwise it will be to long. I even got the VIC to work with the 231, I was going to do a write up on it but nobody seemed interested so I didn't worry about it. Oh I also have a 96, what year was your 231 out of? Mine was out of a 96 xj so the year that you got your donor out of will make a difference.
lonecountryboy is offline
post #179 of 3312 Old 11-04-2010, 10:38 AM
comptiger5000
If you got the 231 and the VIC (not the GDM) working, there would definitely be people interested. AFAIK, nobody else has ever managed it.
comptiger5000 is offline
post #180 of 3312 Old 11-04-2010, 11:29 AM
V852
1994 ZJ
Will a 242 from a 96er XJ fit to my 94er ZJ without modifications?
V8 for ever.
V852 is offline
Currently Active Users Viewing This Thread: 8 (1 members and 7 guests)
silverado94
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 08:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 01:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 05:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 07:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 12:50 PM
