Transfer Case Swap Info NP249->NP231 & NP242 - Page 117 - JeepForum.com
 9Likes
post #1741 of 3311 Old 10-10-2013, 05:29 PM
Platinum5nine
Not used? The VC is in use every time the Jeep is driven
Platinum 5.9 2.25" engine pipes 3" Magnaflow cat, 3" Hooker Aerochamber, 3" tail pipe, Ported kegger, 52MM Throttle Body, 24lb injectors, K&N drop in filter, Cast JEEP valve covers, MSD coil and wires, All new 6 piece clear light kit, 255/65/16 General Grabber HTS, 242 conversion, XJ u-joint front axle shafts
Platinum5nine is offline
post #1742 of 3311 Old 10-10-2013, 05:46 PM
Matt-Barge
1994 ZJ
Well I'm still new to this whole thing so I'm not going to argue semantics with you. I apologize for calling the case crap. I retract my statement. You must really like your 249.
Just call me Barge
'94 Jeep Grand Cherokee Limited
Slow Build-------> http://www.jeepforum.com/forum/f22/new-jeep-owner-offroader-build-1675137/
Matt-Barge is offline
post #1743 of 3311 Old 10-12-2013, 09:08 PM
Platinum5nine
Dont retract anything just read. Above i agreed with you, they are crap in part but not as a whole. The 249 is a strong case and hold up very well other than the VC. The VC is crap they last 100K miles thats about it. I have read guys replacing them at a cost of about $300 and having them fail with in a year. Not worth the headache when a 242 can be had for $100-$150. I pulled my 249 out and put in a 242 a loooong time ago. What i was correcting you on is where you said the VC does bad when its not used. The VC is always used, every time the Jeep is moving. No way around that.
post #1744 of 3311 Old 10-12-2013, 09:21 PM
smccloud
Where are you finding a good 242 for that price? I have yet to find one at a junk yard around me for less than $200 w/o a warranty.
smccloud is offline
post #1745 of 3311 Old 10-12-2013, 09:25 PM
Platinum5nine
Local guys parting out Jeeps. I just pulled one about 3 weeks ago. Came out of a 97 ZJ 4.0 140K miles paid $120 and got the front driveshaft with it and the console shift plate also.
post #1746 of 3311 Old 10-12-2013, 09:27 PM
smccloud
Yeah, doesn't happen in the small town I live in
I miss the 242 my XJ had....
smccloud is offline
post #1747 of 3311 Old 10-12-2013, 09:29 PM
Platinum5nine
If anything id think it would happen in small towns not NY which is one of the most expensive states in the US to live in. Not to mention im from Long Island which is east of NYC and everything out here costs a fortune. I duno man just search im sure you will find one. May take time but its worth it.
post #1748 of 3311 Old 10-12-2013, 09:31 PM
smccloud
I found one a few months ago 60 miles away (Twin Cities Metro) for $150 w/ rear driveshaft, but that was before my VC started going out (only took 230k for mine). Now I'm not sure if he still has it and it doesn't matter yet, gotta save up some money first.
smccloud is offline
post #1749 of 3311 Old 10-12-2013, 09:35 PM
Platinum5nine
Your VC was shot long before 230K miles. No VC lasts that long lol. $150 is top dollar around here. Dont get me wrong guys do ask for more but they just never sell them.
post #1750 of 3311 Old 10-12-2013, 09:38 PM
smccloud
I'm not 100% positive it is the original VC. My Jeep was a builder at some point in its life.
smccloud is offline
post #1751 of 3311 Old 10-12-2013, 09:55 PM
Platinum5nine
It had to have been replaced at some point. Also you may not need the rear driveshaft when you do the swap. I didnt when i did mine. I have a 242 for my other ZJ also. The one thats already dont is 98 ZJ 5.9 no lift at all. Stock rear driveshaft fit perfectly fine and has been that for quite some time now with no issues. Keeping in mind however that i NEVER wheel it. It's got about 1" before it bottoms out which is more than enough. My other ZJ is a 97 with 4.5" of lift. We'll see how that one works out with the stock shaft.
post #1752 of 3311 Old 10-12-2013, 09:56 PM
Platinum5nine
Ah and if i were you, id remove the front driveshaft if your VC is bad before you blow up one of the diffs, or both. A bad VC causes all kinda of stress on the axles and driveshafts which is not good at all.
post #1753 of 3311 Old 10-12-2013, 09:58 PM
smccloud
I don't wheel either.
Think it would be fine to reinstall once it snows? And I should hopefully be getting a raise soon which will allow me to get a "new" 242.
smccloud is offline
post #1754 of 3311 Old 10-12-2013, 10:10 PM
Platinum5nine
I ran mine in 2wd in the snow it was about 3" and i have good tires and had no problems. To run with a bad VC in the snow wont hurt anything though. Just really bad on dry ground.
post #1755 of 3311 Old 10-13-2013, 07:38 PM
Sextiva
I got my 231 for $70 at pullapart. It was from a 98 and bolted directly in.
1996 GC
Sextiva is offline
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 08:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 01:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 05:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 07:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 12:50 PM
