Transfer Case Swap Info NP249->NP231 & NP242 - Page 111 - JeepForum.com
 12Likes
post #1651 of 3412 Old 08-26-2013, 11:47 PM
95chameleonzj
Originally Posted by dnuccio View Post
you'll need to swap inputs
Alright what year would I need to get to not have to swap? Or do I have to no matter what
Sent from AutoGuide.com App
95 jeep grand cherokee 5.2 v8 quadra-trac. Arb winch bumper bds 4.5 inch lift jks upper and lower control arms green and gray two tone hopefully more to come
95chameleonzj is offline
post #1652 of 3412 Old 08-27-2013, 04:18 AM
RagTagSoldier
Originally Posted by zarnold
Mechanical speedometer pickup, but I'm sure it was included. Your going to need the short tab too. Somebody on this forum drilled holes in the long 249 tab and was successful in getting it to work.
Ic well I will do some looking around maybe I'll get lucky and find the post. Thank you!
Sent from my iPhone using JeepForum so it probably looks goofy.
RagTagSoldier is offline
post #1653 of 3412 Old 08-27-2013, 08:37 AM
StridAst
1994 ZJ
You will have to swap no matter what. Well unless you get a drop in rebuilt one from transfer cases unlimited. (Www.transfercase.com) ~$830 if I remember correctly.
StridAst is offline
post #1654 of 3412 Old 08-27-2013, 06:08 PM Thread Starter
JrMechanic
Or transfer case solutions...
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #1655 of 3412 Old 08-27-2013, 08:21 PM
OverlandZJ
So quick question here I have a 95 with the np 249 and I went to the jy and found two transfer cases one 231 and one 242 both rigs are pre 95 one is a zj and one is a xj. Would it just be a direct swap for either one? And what one do you recommend?
I'd grab the 242. In the event it's not the correct length input you could use the 249's front case half guaranteeing a compatible transfer. Just need to drill one hole and swap parts.
I just did such, had a rebuilt XJ 242 w/SYE I wanted to put in my new build.
OverlandZJ is offline
post #1656 of 3412 Old 08-29-2013, 04:04 PM
Myusername1674
Hey all you t-case guys, gotta question. I broke down my 249 today to find out what gear cut my jeep is. My Jeep was born 10-94. So I'm pretty sure it's the later gear cut. Can anyone tell me based on the pictures I've got if this is the new gear cut or the old gear cut?
Do I need to break the out shaft down further to be able to determine? If so let me know and I'll go do it tonight.
Also I found a guy within a few hours of me with an np231 from a 2000 xj. He said he'll sell it for $100 so I'm very tempted to get it. if I do have the new gear cut then I shouldn't have any problems swapping this in right? Any helps great. thanks
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #1657 of 3412 Old 08-30-2013, 06:34 AM
dave_dj1
I'm no expert but if you compare it to the pics on THE FIRST PAGE, it looks to be the newer style.
You do not have to tear it apart any further.
good luck.
Wheel it like ya stole it!
dave_dj1 is offline
post #1658 of 3412 Old 08-30-2013, 06:55 AM
Myusername1674
good luck.
Yeah i believe your right, i pulled it apart more to look at it, and i compared it to pics on a different site. Sweet, now i jus gotta go get a case
Sent from my couch using JeepForum app
(in progress)
post #1659 of 3412 Old 09-04-2013, 12:50 AM
Owens13
Hey there. I am wanting to swap out my tired 249 for a 231. Especially since the VC is taking a southern dive really fast with daily driving and 198k on the clock. After reading several pages in here I have came to the conclusion that since my ZJ is a 1996 with a 5.2, that it has 23 spline .840" input with an Internal slip yoke. I am sure the answer has already been mentioned but after hours of reading i am still not sure what would be the best option to swap out. I see that a 93-95 has the same input spline and measurement but has the collar and have to split the cases to swap inputs anyways. Could someone please tell me if there is a direct, no swapping parts, bolt in fit for my application? Im not against a little work but it would be nice to find a case that is a direct fit if possible. Any help with this would greatly appreciated. Again sorry if this has already been answered but i would like a direct answer so I dont waste time with cases that wont work or ones that are not a good idea. Thanks
Owens13 is offline
post #1660 of 3412 Old 09-04-2013, 07:17 AM
Maine1994ZJ
I'm pretty sure you'll have to do an input shaft swap, regardless.
From what I gather, the V8s all had the 1.5" shaft, and no 231's came with a shaft longer than .840".
I may be off on this, but that's what I recall from the many pages here.
'93 V8 ZJ Mountain Goat Edition.
'95 V8 ZJ Limited, '97 4.0L ZJ TSi
'96 4.0L 2wd XJ, '88 4.2L YJ
Maine1994ZJ is offline
post #1661 of 3412 Old 09-04-2013, 07:49 AM
dave_dj1
Get yourself a nice clean work bench and have at it. The nice thing is you don't have to put your 249 back together!
When shopping for a good set of snap ring pliers, (I got mine at Sears), you don't want the kind with the two points. The kind I use for these particular snap rings are flat on the ends and work great! A set of ones with the points is handy for one snap ring, the rest use the flat ones.
I don't see my exact ones but these are similar
http://www.sears.com/kd-tools-snap-r...blockType=G118
The rings themselves are called E-rings, no holes.
dave_dj1 is offline
post #1662 of 3412 Old 09-04-2013, 08:59 AM
comptiger5000
Only 93 - 95 V8s had the 1.5" shaft. All 96+ ZJs, regardless of engine, have a .840" shaft.
comptiger5000 is offline
post #1663 of 3412 Old 09-04-2013, 09:11 AM
zarnold
Are you going to lock your front axle? If not the easiest and most direct way is to fix your 249. The 242, 231 are both great cases, and will bolt right in, but
you’re most probably going to have to shorten your driveshaft, unless your jeep is lifted. If you’re lifted 3.5" or more you may not have to shorten the driveshaft.
zarnold is offline
post #1664 of 3412 Old 09-04-2013, 05:52 PM
Maine1994ZJ
Thanks for clarifying! Musta missed that tidbit....
post #1665 of 3412 Old 09-05-2013, 03:27 AM
ejschultz
ejschultz's Avatar
If you're on stock control arms, the lift your ZJ might have has very little to do with not having to cut your driveshaft. In fact, on stock arms, you might have to cut it even more if you're lifted. Think about how the axle moves when it droops. The rear of the ZJ is a 4 link radius design. As the axle comes down, it moves more toward the center of the vehicle. What happens to the driveshaft at this point? It moves farther onto the slip yoke on the transfer case to "shorten" the length. As the axle moves closer to the body, like when you hit a speed bump, the axle moves away from the center of the vehicle. This causes the driveshaft to move farther off the slip yoke to "lengthen" it. With leaf sprung vehicles, it's the opposite and lift would make a difference.
ejschultz is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
