Transfer Case Swap Info NP249->NP231 & NP242 - Page 109 - JeepForum.com
 12Likes
post #1621 of 3358 Old 07-02-2013, 10:34 AM
OverlandZJ
Originally Posted by OverlandZJ View Post
Combining an 88 XJ 242 w/sye and a 98 249 front case half/input for my ZJ project. Anyone happen to know what size bit I need to drill the roll pin access hole into the 249's case half?
I don't have a 242 rubber plug on hand to measure..
For future reference... 3/8"
OverlandZJ is offline
post #1622 of 3358 Old 07-02-2013, 07:33 PM
Maine1994ZJ
Originally Posted by JrMechanic View Post
It's best to go by the build date on the transfer case, not the year of the Jeep when determining the gear pitch. Rule of thumb is cases with a build date of pre 94.5 will have the old style gear cut, and cases with a build date of post 94.5 will have the new style gear cut.
Good Luck!
PLEASE!!!
Anybody know which gear cut I would have in a 231 built on 5/10/94?
Is it considered "pre" or "post 5/94?
I have a 50/50 chance of it being the same gear cut as my '93 249(no build tag on 249, ZJ's build date is 11/92) and the way my luck goes, it's going to be the wrong cut....
The 249 is in my DD, so I'd hate to remove it, tear them both apart, find out it's the wrong cut, and then have to put the 249 back together & reinstall to attempt the swap again at a later date.
That would SUCK!!!
Any help will be GREATLY appreciated!!!!
'93 V8 ZJ Mountain Goat Edition.
'95 V8 ZJ Limited, '97 4.0L ZJ TSi
'96 4.0L 2wd XJ, '88 4.2L YJ
Maine1994ZJ is offline
post #1623 of 3358 Old 07-02-2013, 07:53 PM
PhoenixZJ
You can call your local jeep dealership and they can look it up. I suggest calling the parts department. I've had great help with mine or you can PM your VIN too and I can look and see
PhoenixZJ is offline
post #1624 of 3358 Old 07-04-2013, 08:09 AM
Maine1994ZJ
I don't have the VIN from the donor, and it's been crushed and hauled off already...
I'm going out to see which input shaft style the 231 has before I even think about loosening a single bolt on the 249.
post #1625 of 3358 Old 07-04-2013, 04:19 PM
Contadino
SOLD! I have a 242 that I was going to put in my '95 but sold the Jeep last November so don't need it anymore. Open to offers.
Also have the shifter and bezel and front drive shaft. I have pictures I can email to you. SOLD!
Contadino is offline
post #1626 of 3358 Old 07-04-2013, 08:45 PM
zarnold
You might want to post this in the classified section too.
zarnold is online now
post #1627 of 3358 Old 07-10-2013, 03:40 PM
hondakilla98
I picked up a 242 from a 98 zj to swap into my 5.9. The 249 is isy and the 242 is esy, I have the driveline from the 242 as well. I'm just wondering which shaft I should run. I've read that 4.5" and more lift you use the isy shaft because it's longer, but I'm only at 4" of lift. I don't want to take out the rear springs and fully compress the back with each shaft to see which is better if I don't have too.
5.9 Limited, RE 4" lift, RE FTB, JK take offs w/ 255/75/17 BFG MT's, 1.25" wheel adapters, ARB Bumper, Superwinch LP10000, K&N intake, Flowmaster, custom JL & Focal stereo, 20% tint, KOR roof mount tire carrier, JCR sliders, cobra 75 wx st
hondakilla98 is offline
post #1628 of 3358 Old 07-15-2013, 02:59 AM
hondakilla98
Anybody?
post #1629 of 3358 Old 07-15-2013, 03:35 AM
ejschultz
ejschultz's Avatar
Do you have aftermarket control arms? If not, you're probably going to want the shorter driveshaft. As the axle moves away from the body, the radius style control arms keep the axle moving in an arc motion. The driveshaft actually needs to be shorter. If you have aftermarket adjustable arms to keep the axle in the factory location, then you'd need a longer driveshaft. With my lift and control arms, my 242 driveshaft was too short and the 249 driveshaft was too long. I had to cut about an inch off the slip yoke portion of my 249 driveshaft to make it work. I don't recommend cutting it that way. You should probably get it professionally shortened and balanced if you need it shortened, however, I didn't care and it worked out for me, luckily. Every ZJ is a little different though and there are a lot of different length driveshafts these things were fitted with. A definite answer to your question can only be provided by doing the swap and seeing what works.
01 TJ - 4.0L, NV3550, 2" Skyjacker budget boost, Xenon flat flares, Trail Gear front bumper, Tuff Stuff rear bumper, RH4X4 sliders, 33" STT Pros on 15x8s
ejschultz is online now
post #1630 of 3358 Old 07-15-2013, 02:37 PM
hondakilla98
I have adjustable lower control arms in the rear with stock uppers. I've had a little vibration since I lengthened the rear arms. So I shortened them from 17.25-16 7/8 today. Most of my vibration is gone. I guess I'll see what I need to do when I do the swap.
On the freeway I still have some vibration and the axle is where I want it F-R, so I'm looking for used adjustable uppers to tune the pinion angle. And worst case I pay $80 to shorten the driveshaft.
post #1631 of 3358 Old 07-24-2013, 02:12 PM
eagsc7
1994 ZJ
Doing a TRANSMISSION Change, and I THINK this should be put in the first post for 42RE Transmissions with NP231 for the 94 ZJs...
Originally Posted by novak-adapt.com
Torqueflite 42RE Caveat
Unlike all other known transmissions to the Jeep New Process transfer cases, the Torqueflite 42RE transmission as found in 1994 ZJ Grand Cherokees features a unique output shaft with a pilot tip on the end of it. This shaft pilots into the NP input gear in a front-facing caged needle bearing. Note the image below
eagsc7 is offline
post #1632 of 3358 Old 07-26-2013, 12:51 PM
sergio
I just picked up a 242 transfer case. It's from a 1989 XJ. My question is will I be able to change the input from my 1995 249 transfer case to the 242 since the 89 is 21 splines and the 95 is 23 splines?
sergio is offline
post #1633 of 3358 Old 08-11-2013, 08:56 PM
IndianScout
ok, I'm still confused, my Grand Cherokee Limited was built in 12/94 it's a 95 model, I swapped out both rear ends with Chrysler 9 1/4 trac lok's my transfer case is a 249, would this swap do me much good?
with the new rear ends I do notice specially in reverse a bunch of wheel hop and swaying, but forward I'm just fine.
so I would need to find a 242 from an earlier jeep and just change the back end?
IndianScout is offline
post #1634 of 3358 Old 08-13-2013, 04:25 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
You just need to swap the bad viscous coupler from the 249 and you're good.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #1635 of 3358 Old 08-16-2013, 09:22 AM
XIP59L
249 to 242 swap
I just dropped a 242 J from a '98 Laredo donor for my '98 5.9L. Do I need to go back to the scrap yard for wiring , sensors, or anything else from the donor? Also will the rear donor driveshaft bolt in and be fine for now?? Next step is a 6" suspension lift.
XIP59L is offline
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
