Transfer Case Swap Info NP249->NP231 & NP242 - Page 108 - JeepForum.com
 15Likes
post #1606 of 3442 Old 05-28-2013, 03:30 PM
smccloud
Anyone know a good place to get a 242 in Central MN? Don't want the 231 since it would confuse my wife in the winter if she takes my Jeep somewhere but I don't want to replace the VC in my 249 when it finally goes. '97 Laredo w/ a 5.2L.
smccloud is offline
post #1607 of 3442 Old 05-29-2013, 10:56 PM
AlphaLorde
car-part.com
Lists most junkyards in the area
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #1608 of 3442 Old 06-01-2013, 06:52 PM
StridAst
1994 ZJ
I have completed (mostly) my transfer case swap road tested the 242. speedometer works fine, as does 2wd Also, my zj no longer shudders to a stop when decelerating below 20 mph, and the noise the 249 was making is gone. Silence is golden.
Only problem I have had, I still need to work out is the console bezel. I can't seem to get it off to change the plugs behind the VIC =/ going to search more on that and try to figure out what's holding it in. I took all 4 screws out, and the top pulls free, but it's still connected somehow at the bottom below the cigarette lighter. Meh, a problem to tackle tomorrow. On the tired side now. Really pleased though, this was by far the most advanced thing I've ever done with a vehicle. I don't usually even change my own oil.
StridAst is offline
post #1609 of 3442 Old 06-01-2013, 07:51 PM
denk72
You have to pull the ash tray out and there will be two more screws to take out.
denk72 is offline
post #1610 of 3442 Old 06-01-2013, 10:11 PM
StridAst
1994 ZJ
oh, wonderful ty for that
StridAst is offline
post #1611 of 3442 Old 06-06-2013, 01:07 PM
MikeyM
Hi guys,
Have been going through this for a while. Seems the 242 swap from 97-98 ZJs is a direct bolt in for the 5.9; inputs the same and lenght of various components making DS swaps unnecessary but what about the 5.2? Mine has a 4"lift with stock front and rear DS. Also, I have the HD front DS from the factory with U-joints (non-CV style). Is it a direct bolt in for the 5.2 as well? Of course I would take as many measurements as I could with respect to case lengths, etc. but want to throw that out there.
Thanks!
Mikey
'98 ZJ 5.2L V8, full intake, exhaust, & ignition mods, Rusty's 4" coils with front TB conversion, rear ORGS TB, OME long travels & SS, Tera QDs, Yakima rack w/goodies, BFG 31" MT/KMs, full skids, front and rear diffy guards, Donavee rear swing-out tire carrier. 213k, 18-19 hwy.
MikeyM is offline
post #1612 of 3442 Old 06-06-2013, 01:11 PM
lil_joe
My 242 bolted directly in, I have the 5.2
Mike
____
lJeepl
--[.]IIIII[.]
Obsession is a word the lazy use to describe the dedicated
HER's: 92 YJ 4" RC 1.5 RC Booms, 1" BL on 33's
MINE's: 97 ZJ 5.2 Upcountry Limited Project 2" RE BB on 265/75 Mud Dogs, Locked front LSD rear, 242 swapped T-Case, RC Quick Disco's
lil_joe is offline
post #1613 of 3442 Old 06-06-2013, 01:19 PM
ejschultz
Originally Posted by MikeyM View Post
Hi guys,
Thanks!
Mikey
I took about an inch off the slip yoke of my original DS from the 249. Other than that, it bolted right up.
ejschultz is offline
post #1614 of 3442 Old 06-06-2013, 02:01 PM
MikeyM
Thanks guys,
Lil Joe, you just got the 97-98 242 and swapie swap, huh? You running any lift? The front and rear DSs looked ok, no over compression etc.? I assume all measurements were not exactly the same as the original 249 case but nothing to worry about it seems. Did you go from internal SY to external and the rear DS splines just slid right on?
EJ - you're referring to the rear DS, correct? Looking back would you still take an inch off? I have a 4" lift (like you) and am wondering if the DS is pulled back enough for me to not have to cut it.
Thanks again!
MikeyM is offline
post #1615 of 3442 Old 06-06-2013, 02:07 PM
lil_joe
Im at 3.5, but I have a front SYE and XJ style front shaft, the PO set it up like that
Mike
____
lJeepl
--[.]IIIII[.]
lil_joe is offline
post #1616 of 3442 Old 06-06-2013, 05:17 PM
zarnold
Hi guys,
Thanks!
Mikey
You should be fine, the only real issue is the rear DS length. With 4" of lift that will be negated. Let us know how it turns out.
zarnold is offline
post #1617 of 3442 Old 06-06-2013, 05:40 PM
ejschultz
Thanks guys,
Thanks again!
On stock control arms, you might have to take off more than I did. On adjustabls or fixed aftermarket arms, the axle should move back a little. In this case (my case) you'll have a minimal amount to trim. And yes, I'm talking about cutting the yoke on the driveshaft.
post #1618 of 3442 Old 06-08-2013, 06:24 AM
Maine1994ZJ
After reading this whole thread, I think I got the easiest case to swap for my application.
My 249 has no build tag on it, but the ZJ has a 5.2L, was built 11/92, and the 249 has ISY.
The 231 I got from the JY for $20 has a build date of 5/10/94, ISY, and came off a 4.0L.
If I understand correctly, I will only need to swap input shafts(seals, etc. too) for this to work correctly.
PLEASE correct me if I'm misunderstanding something, I want to make sure my ducks are all in a row before getting elbows deep in this swap.
Thanks, Rob
'93 V8 ZJ Mountain Goat Edition.
'95 V8 ZJ Limited, '97 4.0L ZJ TSi
'96 4.0L 2wd XJ, '88 4.2L YJ
Maine1994ZJ is offline
post #1619 of 3442 Old 06-11-2013, 08:13 PM
David97
Errr nevermind. Little more searching and I got my answers.
David97 is offline
post #1620 of 3442 Old 06-29-2013, 06:11 PM
OverlandZJ
Combining an 88 XJ 242 w/sye and a 98 249 front case half/input for my ZJ project. Anyone happen to know what size bit I need to drill the roll pin access hole into the 249's case half?
I don't have a 242 rubber plug on hand to measure..
OverlandZJ is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
