Transfer Case Swap Info NP249->NP231 & NP242 - Page 106 - JeepForum.com
 14Likes
post #1576 of 3441 Old 04-24-2013, 08:18 AM
bigb229
so how much chain slack is too much slack? I get about a half inch of droop in mine and that's a bit much for my taste
bigb229 is offline
post #1577 of 3441 Old 04-24-2013, 01:01 PM
denk72
Im doing a front case swap. Since the 249 and 242 have the same front case the seals for the front input and front output are the same right?
denk72 is offline
post #1578 of 3441 Old 04-24-2013, 01:09 PM
denk72
The same between the 249 and 242?
denk72 is offline
post #1579 of 3441 Old 04-25-2013, 07:18 AM
01blackout
is there a new part number for that tcase linkage "bearing" the link on quadratec is no good anymore
THE ZOMBIE HUNTER*1997 jeep grand cherokee zj*5.2*exploder wheels*stock wheels*2" budget boost*d30*d44*current daily driver* working on building her up!*
BLACK OUT 2001 60th anniversery TJ*4.0*soft 8's*33x12.5 dunlap mudrovers* kc daylighters*3.25 rough country suspension lift*d30*d44* BUILT NOT BOUGHT!!!!! (sold)
01blackout is offline
post #1580 of 3441 Old 04-25-2013, 09:00 AM
bigb229
if you'll google np 242 parts/quadratec....it'll pop up the parts page and you'll see the listing for the bushing kit
bigb229 is offline
post #1581 of 3441 Old 05-01-2013, 06:18 PM
AlphaLorde
I did my 231 swap, got my driveshaft shorted, replaced a ujoint and balanced.
I got harsh vibes while accelerating from 45mph up to about 52mph. But only gives vibes under power. If I'm coasting or holding a steady speed in that range i get no vibes. I also get a very slight vibe 65+.
I think my pinion bearing on my 44a has a slight amount slop in it. I can click/clink the pinion shaft around in the housing. Could this be casusing my vibes? Any help will be appreciated.
My pinion angle is within a degree of the tcase output.
I just hope that I dont have to bite the bullet and go sye. The positive side of it though is I already have a spare double cardan cv DS to use.
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #1582 of 3441 Old 05-02-2013, 06:29 PM
Palozo
Good evening guys!
I have a GC Laredo 1998 4.0, 4-speed automatic gearbox, and NP 249 T-Case. I live in Brazil, so my apologies for my bad English.
Some time ago I was thinking about fuel saving. You know Brazilian gasoline is no much better than piss granny (grannies pardon-moi!). So here there are some solutions used by Brasiilians owners since 20 years ago (or more).
1-Convertion a gasoline engine to alcohol engine.
Expensive conversion. Engine must be over compressed. Normally from 8.9:1 to 11.0:1 to burn alcohol efficiently. Sometimes the ECU must be reprogramming or changed. No way for Cherokees or other car from USA Europe or Japan market.
2-GNV installation. In this case car burns gasoline and/or GNV gas or alcohol and/or GNV gas. Anyway it's a expensive process too! Install GNV cylinders, new ECU, change spring (GNV cylinders are very weight!). Egines usually lose 15% in its BHP and fuel injector works over-heated.
My ideia is (just speculation) to install a T-Case wiht 2wd option. I drive 99% time in highway or cities. Never offroad. So a 2wd T-case would be welcome.
But I'm NOT sure about fuel saving with different T-case. I would need a comparisson between 2wd and 4wd performance on highway. Can someone help me?
Thanks
Palozo
Palozo is offline
post #1583 of 3441 Old 05-02-2013, 06:39 PM
comptiger5000
Unless you install hub lockouts on the front hubs, running in 2wd vs 4wd doesn't affect gas mileage. All the 4wd bits are still spinning, just with no power applied. If you got hub lockouts for the front (not cheap), you'd probably gain about 0.5 mpg from reduced drivetrain friction when in 2wd.
By the way, your English is actually not bad at all. I see far worse on a regular basis from people who've spoken English from birth.
comptiger5000 is offline
post #1584 of 3441 Old 05-02-2013, 09:38 PM
love2offroad
1994 ZJ
I'm new to the jeep forum and want to build my first crawler, but want to use it as a daily driver as well. To start off, I have a 94 Grand Cherokee (build date 10/93). The transfer case in it is the notorious 249, although the date of the transfer case that is in it says "3 27 96 3". According to what was stated earlier in this thread tells me this was manufactured march 27 of 1996. What i want to know is will the output shaft be the .840 like the 96-98 should have like stated above, or will i have the 1.55" like the 93-95 V8 should have? Any input would be much appreciated. For reference though, I want to swap to a 231 transfer case. Thoughts? Things i should worry about?
love2offroad is offline
post #1585 of 3441 Old 05-08-2013, 03:51 PM
JArnett0913
1994 ZJ
Hi,I have a question for you guys on the swaps.Is it a direct swap from an NP249 to an NP231 or do I need to change the front case halves?I have the driveshafts and everything from the donor jeep.I have a 94' Grand Cherokee Laredo with the 318 V8 and the donor NP231 is coming out of a 93' Grand Cherokee Laredo with the Inline 6.I actually own both jeeps but the 93' is a parts jeep.Thanks,Johnny.
JArnett0913 is offline
post #1586 of 3441 Old 05-10-2013, 12:56 PM
speedbucket
the answers to that are all in this thread but im feeling generous
you will need to use the input off of your 249 (its 1.55" exposed)
the I-6 input shaft is not long enough.
you will use everything from the 231 but the input shaft
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #1587 of 3441 Old 05-10-2013, 03:17 PM
JArnett0913
1994 ZJ
Thanks speedbucket for being so generous and I mean that sincerely.I wasn't quite sure about it and didn't feel like reading 100 plus pages too many things to do and never enough time.
post #1588 of 3441 Old 05-13-2013, 03:35 PM
mandrews000
Finally got around to fitting the 231 in... Forgot to change the input shaft though... That's what happens to a project that's been open for over 6 months.
Turns out the 231 my brother gave me, which was supposedly a 95, is actually a late 93... This complicates things...
mandrews000 is offline
post #1589 of 3441 Old 05-14-2013, 07:04 PM
StevieB76
Ok, so if I am understanding correctly..since my 95 ZJs(4.0l) NV249 has a build date of 1-27-95 and has an internal slip yoke it has a .840" 23 spile input. If I wanted to switch to a NV242 I would be looking for one with a 95 or newer build date from a 95-01 XJ...if I am understanding correctly?
StevieB76 is offline
post #1590 of 3441 Old 05-15-2013, 10:10 AM
speedbucket
That build date is gonna be a crap shoot on the new gear cut vs. Old gear cut.
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
