Transfer Case Swap Info NP249->NP231 & NP242 - Page 105 - JeepForum.com
 12Likes
post #1561 of 3345 Old 04-09-2013, 03:46 AM
ejschultz
ejschultz's Avatar
So you guys know, against your (and my) better judgement, I cut my rear driveshaft on the slip yoke when I did my swap this weekend. I took off about an inch and a quarter to an inch and a half. I did it the wrong way and didn't measure at all. I just eyeballed it. Some may say I got lucky. Others may say I'm an idiot for trying. It works. It doesn't bottom out at full droop and, although it'll probably never happen, at full compression of the rear suspension it doesn't drop. It's a perfect fit for my 242 and D44a. I also managed to do such a good job with a reciprocating saw, I don't even get any vibrations. All in all, I'd say I'm happy with the outcome.
01 TJ - 4.0L, NV3550, 2" Skyjacker budget boost, Xenon flat flares, Trail Gear front bumper, 33" STT Pros on 15x8s
ejschultz is offline
post #1562 of 3345 Old 04-09-2013, 10:54 AM
90xjblue
1990 XJ Cherokee
Hi guys, just looking for a confirmation on the compatible years of tcase.
I have a 1990 xj and a 1991 xj both auto both have 231 tcases.
My 1990 has a sye in the tcase, i want to swap that into my 91, the whole case to avoid tearing it apart and moving sye. I have been told the input shafts to the tranny changed from 21 to 23 in 1991 but this thread contradicts that.
So is it a direct swap or will i need to pull out the input shaft or sye and swap it into the 1991 case?
thabjs
90xjblue is offline
post #1563 of 3345 Old 04-11-2013, 10:05 AM
Mark-318-IT
hi guys, finally, tomorrow i'm installing the 242...now i have to ask you a question: with the 249 to engage 4lo i have to go very slow (like 4-5 km/h) put in N and pull back the leverage while the car is still moving. With the 242 is it the same story? do i have to go very slow, put in N and pull back the tcase's leverage? or can i do it wihle the car is stopped?
car is 98 limited 318
thanks guys
Mark-318-IT is offline
post #1564 of 3345 Old 04-11-2013, 10:15 AM
Freestyle713
1994 ZJ
Quick question, which cases share the same main shaft as the early np231? I'm thinking of getting one to get rid of my hack n tap sye and put my old driveshaft back in to see if my vibes go away.
94 Grand Cherokee 5.2 33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's
Originally Posted by elcorvino View Post
Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.
Originally Posted by ScottD16 View Post
I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.
Freestyle713 is offline
post #1565 of 3345 Old 04-11-2013, 10:30 AM
ejschultz
ejschultz's Avatar
Anytime you shift any transfer case into 4 low, you need to be going 0-3 mph, preferably not 0, with the vehicle in neutral. This holds true for every NP/NV transfer case I've ever encountered across all makes.
post #1566 of 3345 Old 04-11-2013, 11:00 AM
Mark-318-IT
understood thanks, and what about the 2wd--->4wd part time? and from 4wd part to 4wd full?
thanks
post #1567 of 3345 Old 04-11-2013, 11:07 AM
ejschultz
ejschultz's Avatar
According to the manuals, not over 55 mph. Anything under that should be okay, assuming the transfer case is in good working order. I don't like switching at speeds much above 40. There really shouldn't ever be a need to though. That being said, I found my Nitro will shift from 2 wheel drive to 4 hi at 75 mph. I wouldn't recommend doing it though.
post #1568 of 3345 Old 04-11-2013, 11:27 AM
comptiger5000
Also, when shifting 2hi/4ft/4pt, you have to be going STRAIGHT. I find it's best to shift while coasting, and then very, very lightly apply throttle to unload the driveline, and it should go right in.
comptiger5000 is offline
post #1569 of 3345 Old 04-11-2013, 11:43 AM
Mark-318-IT
10.4 thanks for all these infos...so in the end: going straight, not over 55 and tranny in N (i'm talking about HI gears, not 4lo). Right? thanks again
post #1570 of 3345 Old 04-11-2013, 11:49 AM
ejschultz
ejschultz's Avatar
The tranny doesn't need to be in neutral. Sometimes if the driveline has tension, neutral can help, but you shouldn't necessarily have to.
post #1571 of 3345 Old 04-11-2013, 12:04 PM
Mark-318-IT
good to know, thanks again
post #1572 of 3345 Old 04-12-2013, 09:06 AM
caroedell
I was lucky enough to find a 1992 242J case for $90.00. It was even rebuilt and in excellent condition. Even though produced on January 15, 1992, it has the 23 spline input. I understand this would require a front case swap as the input bearing size and planetary gear cut are different. Has anybody done a work up on the front case swap? It looks as if I need to swap the shift fork positioner and the transfer chain gears. Since the 249 has a solid front output shaft with drive gear, they would have to be switched as well.
So how much of a difference is it to leave the original .750" input shaft as opposed to the .840? This is getting to a big pain already
caroedell is offline
post #1573 of 3345 Old 04-15-2013, 09:48 PM
knower
Hi guys!
I have found a np231j transfer case from a 1997 TJ.
Would this be good to replace the NV 249 that is on my ZJ 1997?
Thanks very much!
G.
knower is offline
post #1574 of 3345 Old 04-16-2013, 12:50 PM
leadfootny
Kudos to the OP for the write up. Just did this swap in my 5.9. I was able to use my rear d/s with the 242. The one out of my 96 was way too short, plus the rear u-joint too small. I have about an inch left on the rear output shaft. Pulling out of my driveway (which is the most amount of flex this Jeep will do), it didn't bottom out so I think I will be good. The 249 is ISY and the 242 is ESY.
96 ZJ 4.0
98 ZJ 5.9
leadfootny is offline
post #1575 of 3345 Old 04-17-2013, 08:45 PM
chetzar
1994 ZJ
Anyone know if Jr. is still around? I'm tried to PM him, but his inbox is full...
chetzar is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
