Transfer Case Swap Info NP249->NP231 & NP242 - Page 103 - JeepForum.com
 9Likes
post #1531 of 3311 Old 02-21-2013, 07:13 PM
zarnold
Originally Posted by Mark-318-IT
hi guys now i have a 98 limited 318 with the 249 but the vc is going bad...so i'd like to swap a 242.
i have a big doubt with the 242: can i use 4wd full-time at any speed? like the 249? or do i have some limits?
Yes, the 242 has full time 4wd which works great.
zarnold is offline
post #1532 of 3311 Old 02-22-2013, 03:36 AM
Mark-318-IT
understood thanks, so i do not have any speed limit with the "4wd mode", right?
Mark-318-IT is offline
post #1533 of 3311 Old 02-22-2013, 04:10 AM
ejschultz
ejschultz's Avatar
It is recommended that you don't shift over 55 MPH.
01 TJ - 4.0L, NV3550, 2" Skyjacker budget boost, Trail Gear front bumper, 31" Duratracs on 15x8s
ejschultz is offline
post #1534 of 3311 Old 02-22-2013, 05:29 AM
Mark-318-IT
Ok, tell me if i'm understanding right: shifting = changing gears...for example from 2wd to 4wd full-time, correct?
This is not a limit about using that gear.
So i can't shift from to 2wd to 4wd over 55 mph, but i can use 4wd over 55 mph...correct?
thanks and sorry for my english
post #1535 of 3311 Old 02-22-2013, 07:29 AM
comptiger5000
Correct. But in my experience, if you have enough traction to safely do more than 40mph, there's no need to be in 4wd anyway.
comptiger5000 is offline
post #1536 of 3311 Old 02-22-2013, 08:56 AM
leviharbour
rear seal
Originally Posted by Andrewm6097 View Post
I picked up a 242 out of a 98 grand cherokee. I'm replacing the seals but I'm having trouble finding the correct rear output seal. In the picture, left is the original, middle is national brand part #4370n, on the right is timken brand part #4370n. What gives? They're all different and both the new ones have too small of a diameter to even fit. Anyone else have this problem? Where should i get the correct part?
Attachment 568617
I had the exact same problem for about a week of looking. I eventually found mine at Carquest. I will look around for the box on mine and see if I can find the part number for you. I know it was "...118.." something. It isn't the part number they list.
leviharbour is offline
post #1537 of 3311 Old 02-22-2013, 10:28 AM
Mark-318-IT
thanks
post #1538 of 3311 Old 02-22-2013, 07:51 PM
Andrewm6097
The seal i found at Napa was part# 18108.
Maybe this should be added to the original post with the seal information?
Andrewm6097 is offline
post #1539 of 3311 Old 02-22-2013, 08:12 PM
zarnold
Nice! PM this to JrMechanic. Make sure you mention which TC you were working on.
zarnold is offline
post #1540 of 3311 Old 02-26-2013, 12:37 PM
ghatid
Does anyone happen to know how much the output from the tcase should overlap with the drive shaft? I got a new drive shaft that turns out is 3 inches shorter than my original one...it seems to only overlap the output spline about 2inches which doesn't seem like it's enough for me.
ghatid is offline
post #1541 of 3311 Old 02-26-2013, 03:57 PM
Danish
1994 ZJ
What's going on Guys, great thread about the tc swap....more information than I can take in, lol.... Anyways I am having major issues with my jeep. I have a 94 Zj v8 with a pn249 it has a rustys long arm 35s an sits with a 5.5 in lift. The problem I am running into is a loud popping noise and binding in the tc and front drive shaft, here is a video link of what it is doing:
any help or suggestions would be awesome. I currently have the transfer case torn apart and it looks like everything is in working order, other than the VC of course, but the chain and gears all look good. I am pretty new to the jeep world and I am at a loss of what I need to do.
Thanks man!
Danish is offline
post #1542 of 3311 Old 02-28-2013, 09:57 PM
mandrews000
Video Link: http://www.youtube.com/watch?v=wor0D4TW3tk&sns=em
Thanks man!
Can you rotate the wheels with them off the ground and the Drive shaft disconnected? Have you opened your diff?
If there's nothing wrong with you diff your chain could be stretched.
mandrews000 is offline
post #1543 of 3311 Old 03-02-2013, 07:50 AM
zarnold
Thanks man!
So if internals of your TC case look OK, and the chain is not stretched, reinstall it, and fill it to the proper level. Now test it with no driveshafts. Just see if you can reproduce the popping with no load (I don't think you'll be able to). Then test without the front driveshaft. Remember you can only test it, do NOT drive without your front driveshaft for anything other than a test, otherwise you'll do more damage to the TC, and know that it will roll in park without both driveshafts, so make sure your on level ground. If no binding in the back, reinstall your front, and test again.
zarnold is offline
post #1544 of 3311 Old 03-02-2013, 01:39 PM
Danish
1994 ZJ
Thanks for the help guys. I was lucky enough to have a friend who had a rebuilt 249 just laying around, put that old girl in and no more noises. So it definitely was something bad in the original tc
Danish is offline
post #1545 of 3311 Old 03-02-2013, 07:14 PM
lil_joe
I think I got "swindled" on a t-case. The one I bought has a build date of 9-8-2000, 231J, but is about 1.5 inches longer than my 249, and does NOT have place to connect the speedometer, and the rear shaft is larger in diameter than mine. The labeling on the tag is correct for what I need, but all that I have read here, there is no mention of rear shafts being larger, could this be out of a Dodge?
Mike
____
lJeepl
--[.]IIIII[.]
Obsession is a word the lazy use to describe the dedicated
HER's: 92 YJ 4" RC 1.5 RC Booms, 1" BL on 33's
MINE's: 97 ZJ 5.2 Upcountry Limited Project 2" RE BB on 265/75 Mud Dogs, Locked front LSD rear, 242 swapped T-Case, RC Quick Disco's
lil_joe is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 08:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 01:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 05:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 07:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 12:50 PM
