Transfer Case Swap Info NP249->NP231 & NP242 - Page 100 - JeepForum.com
 12Likes
post #1486 of 3345 Old 01-26-2013, 01:24 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Originally Posted by 98GCLimited View Post
Thanks man I just went for it and bought it.
Worst case scenario I need to swap inputs, planetarys, and front case half and adjust rear driveshaft length but thinking it could possibly be a direct bolt in which would be sweet.
you can't swap a front case half from a 249 to a 231, the cases are different.
the early model has a shallow collar or ring seated into the female end of the input shaft. you need to knock that out to use that case with a later model transmission.
ratmonkey is offline
post #1487 of 3345 Old 01-26-2013, 01:46 PM
98GCLimited
Ok, thanks for letting me know that, I didnt know.
I found that thing about the collar in this thread, but I just cant quite picture how its in there and how to get it out without seeing it myself or a picture of it. (I ordered it off the internet, so I dont physically have the case yet but I bought it already.)
Do I need to pull the case apart and take the input out to get the collar out or can it be pulled out of the input from the outside somehow and I wouldnt need to open the case?
Thanks for the help so far guys
98GCLimited is offline
post #1488 of 3345 Old 01-26-2013, 09:08 PM
airwolf9090
May be dumb thing to ask but can the output's be switched from External to internal? Like take the output housing off a 249 and put it on a 242?
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #1489 of 3345 Old 01-26-2013, 11:37 PM
Jeeples
Jeeples's Avatar
That's a good question.
I actually had to put my swap that I had planned for today because I assumed my '96 MY (late '95 build date) ZJ had the ESY like the donor '97 242 t-case had. When I went under to pull the rear driveshaft I noticed my 249 had the ISY.
Can I swap outputs or am I stuck snagging the driveshaft from the donor Jeep or having my factory one shortened?
EDIT: I guess I could swap case halves correct?
DOUBLE EDIT: I eventually plan on a 3-3.5" lift, so is there any advantage to swapping driveshafts, swapping case halves or have the driveshaft shortened?
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #1490 of 3345 Old 01-27-2013, 10:04 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
No, you can't swap outputs.
Have your shaft shortened.
post #1491 of 3345 Old 01-27-2013, 11:01 AM
Jeeples
Jeeples's Avatar
I'm hoping I can find a decent donor. The wrecking yard I got the case from has several 96-98 ZJs with the 242 in it and if I go on a Wednesday a driveshaft would only cost me $14.
Would any 96-98 242 ESY rear drive shaft work regardless of engine/trans or am I going to need to find one out of an eight cylinder?
Jeeples is offline
post #1492 of 3345 Old 01-27-2013, 01:22 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
8cyl never came with the 242
you're probably not going to find a drive shaft to bolt right in. the drive train lengths and pinion positions are different between the i6 and v8 models.
post #1493 of 3345 Old 01-27-2013, 08:11 PM
x10radsponge
Ok, probably gonna get flamed here but I was at pull a part saturday and had 242's laying on the ground all around me. Problem is, not 100% on donor jeeps. I have figured out that my niner has the .840 23 spline input shaft, but what year XJ's and ZJ's are a direct fit. I think most of the 242's are from XJ's. I may have missed it and honestly have not read all 100 pages but is there a table of "this is your year, this is what fits" floating around?
x10radsponge is offline
post #1494 of 3345 Old 01-27-2013, 08:34 PM
airwolf9090
If i had the money i would but all the local shops want $200 to do it. And every junk yard around here lifts from the side making driveshafts unusable and the 1 place that lifts from the front don't have what i need and the one place stateboro jeep junkyard wants about $150 for a Driveshaft.... Its driving me nuts....
1996 Jeep ZJ Orvis
post #1495 of 3345 Old 01-27-2013, 08:35 PM
98GCLimited
You could try this link it might help.
http://www.drivetrain.com/parts_cata...arts/jeep.html
post #1496 of 3345 Old 01-27-2013, 09:07 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
you can buy a whole new shaft for that kind of money. even the way overpriced shop around here don't charge that much for a cut and balance on a rear shaft. they want 275 for a front cut and balance though.
that's why i do my own.
post #1497 of 3345 Old 01-28-2013, 06:48 PM
ghatid
Just curious, earlier you said to only cut the shaft and not the output of the tcase, why is that?
ghatid is offline
post #1498 of 3345 Old 01-28-2013, 07:08 PM
ejschultz
ejschultz's Avatar
Can't you cut the slip yoke on the driveshaft? I've heard numerous success stories going this route. I've heard an inch to an inch and a half is best.
01 TJ - 4.0L, NV3550, 2" Skyjacker budget boost, Xenon flat flares, Trail Gear front bumper, 33" STT Pros on 15x8s
ejschultz is offline
post #1499 of 3345 Old 01-28-2013, 07:25 PM
mandrews000
If you cut the slip yoke only the output shaft will still bottom out in the yoke. The best option is having your drive shaft cut down. I had mine cut down and balanced for $40 cash each. They said 80 I said I have 2 how about 40 a piece no special treatment just cut, welded and balanced... Deal!
mandrews000 is offline
post #1500 of 3345 Old 01-28-2013, 07:51 PM
ejschultz
ejschultz's Avatar
I'm hoping between my rear adjustable upper arms, my shaft, and the donor shaft, I'll get away without having to get one cut.
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
