Transfer Case Swap Help - JeepForum.com
post #1 of 2 Old 07-17-2011, 07:59 PM Thread Starter
coolsurfer88
so i was going through the swap with no issues and then all of a sudden...
i was pulling the 249 and when i started separating the tcase from the trans i had a bunch of fluid start leaking out it is red in color and was coming out of the rear and i would say probally a quart or quart and a half came out of the back of the transmission (well i think thats where it came from)
as i was moving the transfercase the rear output (mine had the metal housing over the slip yoke it leaked out a bunch of fluid also..
and they looked similar in color..
so is it safe to say my rear seal on the trans is gone?
or was the fluid coming from the front of the transfer case?
i dont know and i need my jeep fixed asap i am going to do the rear seal tomorrow but is that much coming out normal?
should i be checking for other problems?
any help or input is appreciated...
coolsurfer88 is offline
post #2 of 2 Old 07-17-2011, 09:45 PM
TewSmooth18
did you drain the fluid from the transfer case prior to unbolting it? and, if you lowered the tranny any then that is why the fluid came out from the tranny, it's completely normal. also, if you did drain the transfer case prior to removing like you're supposed to, it will still probably leak some fluid that didnt get completely out when drained, just pull it off and take a look at the seal
as far as them looking similar in color, that's because they are BOTH ATF fluid. tranny and transfer case both take the same fluid
97 Grand Cherokee 5.2 V8 - 242 swap - everything else stock atm
TewSmooth18 is offline
Transfer case swap jeepgc99lmtd ZJ Grand Cherokee Forum 1 12-07-2009 08:25 PM
Transfer Case Swap 98 ZJ: 249 Out, 242 In daphne ZJ Grand Cherokee Forum 10 10-25-2009 07:30 PM
Transfer Case Swap CrawfishStu ZJ Grand Cherokee Forum 27 02-25-2006 07:04 PM
Transfer Case Swap CrawfishStu ZJ Grand Cherokee Forum 7 12-16-2005 09:20 AM
transfer case swap blackblazer92 ZJ Grand Cherokee Forum 7 05-16-2005 06:16 PM
