Transfer case swap..... - Page 3 - JeepForum.com
post #31 of 47 Old 07-11-2014, 09:57 AM
DrPepper46
Don't forget, now is the time to....
Change the Transmission rear seal and the TC seals, easy when it's out.
Nothing like getting done and finding a puddle on the ground...
Don't forget the fluid of choice for the 242 is ATF4 not the $$Mopar$$ stuff.
Swapped mine last fall, wonderful...!!!
DP
DrPepper46 is offline
post #32 of 47 Old 07-11-2014, 02:20 PM Thread Starter
travisyoung
1994 ZJ
Is that really a 242 case? Im a little concerned that theres no id tag
travisyoung is offline
post #33 of 47 Old 07-11-2014, 02:21 PM Thread Starter
travisyoung
1994 ZJ
Originally Posted by DrPepper46
Change the Transmission rear seal and the TC seals, easy when it's out. Nothing like getting done and finding a puddle on the ground... Don't forget the fluid of choice for the 242 is ATF4 not the $$Mopar$$ stuff. Swapped mine last fall, wonderful...!!! DP
I was planing on doing that!
post #34 of 47 Old 07-11-2014, 03:35 PM Thread Starter
travisyoung
1994 ZJ
He sent me theses, so can i tell by these numbers what T case it is?
post #35 of 47 Old 07-11-2014, 03:44 PM
94cherry
1994 ZJ
Loos like a 242. I have a 231 on the ground and the rear case half from top to bottom is not as high as the one in the pic.
Kiss my shiny metal bumper.
94cherry is offline
post #36 of 47 Old 07-11-2014, 04:50 PM Thread Starter
travisyoung
1994 ZJ
Oops the picture didnt load
post #37 of 47 Old 07-11-2014, 04:51 PM Thread Starter
travisyoung
1994 ZJ
I guess I'm going to get it tomorrow night
post #38 of 47 Old 07-13-2014, 05:41 PM Thread Starter
travisyoung
1994 ZJ
I passed on it. It just seems to good to be true and it not having a id tag is concerning to me i found one on ebay out of a 93 GC Im umsuming itll fit fine ? And what what drive shaft do i need?
post #39 of 47 Old 07-13-2014, 05:47 PM
94cherry
1994 ZJ
242,232 249? Drive shafts should be direct swap as long as the TC is from a pre 94.7. Even though its a 93 Gc doesn't mean someone didnt swap a newer TC into it at some point. Ask the seller for the serial number so you can get the build date of the TC.
94cherry is offline
post #40 of 47 Old 07-13-2014, 05:50 PM Thread Starter
travisyoung
1994 ZJ
post #41 of 47 Old 07-13-2014, 05:55 PM
94cherry
1994 ZJ
Change the front input shaft all the seals and you will be good to go.
94cherry is offline
post #42 of 47 Old 07-13-2014, 06:12 PM Thread Starter
travisyoung
1994 ZJ
Sweet thanks! I was planing on putting all new seals and bearings in
post #43 of 47 Old 07-13-2014, 10:41 PM Thread Starter
travisyoung
1994 ZJ
Well i got the case anything else i should get?
post #44 of 47 Old 07-14-2014, 05:50 AM
94cherry
1994 ZJ
5 quarts of ATF for mopar. I lost about 3 out of the trans and the tc takes 2. Should do your Ujoints while they are out also. Wouldn't hurt to change diff oils if they haven't been done in a while.
94cherry is offline
post #45 of 47 Old 07-14-2014, 07:50 AM
PolkaPower
Use atf-4. Any brand will do since to have atf-4 on the label is has to meet Chryslers standards. Even house brand atf-4 is great quality.
PolkaPower is offline
