Transfer case swap..... - Page 2 - JeepForum.com
post #16 of 47 Old 07-08-2014, 08:53 PM
94cherry
1994 ZJ
Originally Posted by travisyoung View Post
Damnnn haha i better start reading
The first page is the most important.
Kiss my shiny metal bumper.
94cherry is offline
post #17 of 47 Old 07-08-2014, 09:07 PM
PolkaPower
All 249 are internal slip yoke.
PolkaPower is online now
post #18 of 47 Old 07-10-2014, 05:18 PM Thread Starter
travisyoung
1994 ZJ
travisyoung is offline
post #19 of 47 Old 07-10-2014, 05:38 PM Thread Starter
travisyoung
1994 ZJ
Heres his email
post #20 of 47 Old 07-10-2014, 05:50 PM
94cherry
1994 ZJ
Where are you at In CA? What are the specs on your Jeep, IE engine,year and what TC do you have now?
94cherry is offline
post #21 of 47 Old 07-10-2014, 05:53 PM Thread Starter
travisyoung
1994 ZJ
In the bay area and i have a 94 5.2 gc limited auto (not sure which one) and it has the 249 in it now with the VC on its way out
post #22 of 47 Old 07-10-2014, 08:40 PM
kg6mov
Hears the voices
kg6mov's Avatar
Trans would be the 46rh. You would need to swap the input shafts, you probably have the same "old style" gear cut as the yj case. Double check the build day on the transfer case in your jeep to be sure.
kg6mov is offline
post #23 of 47 Old 07-10-2014, 09:34 PM Thread Starter
travisyoung
1994 ZJ
It has the same drain plug like the 30mm instead of the allen one. Did the change the gear cut at the same time they switch plugs?
post #24 of 47 Old 07-10-2014, 09:36 PM
kg6mov
Hears the voices
kg6mov's Avatar
I wouldn't bank on it.
kg6mov is offline
post #25 of 47 Old 07-10-2014, 09:38 PM Thread Starter
travisyoung
1994 ZJ
Hmmm well **** for 75$ ill take the risk if its the wrong one ill just sell it
post #26 of 47 Old 07-11-2014, 12:25 AM Thread Starter
travisyoung
1994 ZJ
Is there a way to id the tcase without the id tag?
post #27 of 47 Old 07-11-2014, 01:30 AM
kg6mov
Hears the voices
kg6mov's Avatar
Not really? Do you have the build date for the jeep? If it was built pre 94 it should be good (can't have made the case after the jeep).
kg6mov is offline
post #28 of 47 Old 07-11-2014, 01:42 AM Thread Starter
travisyoung
1994 ZJ
No... He doesn't have the id tag
post #29 of 47 Old 07-11-2014, 01:55 AM
kg6mov
Hears the voices
kg6mov's Avatar
Oh, no the case out of the YJ is old style cut and you're fine if your case is too, they changed mid 94.
kg6mov is offline
post #30 of 47 Old 07-11-2014, 06:00 AM
94cherry
1994 ZJ
I am no expert but it looking at the pic he will have to change his speedometer input from his 249 and that case also looks like it is missing the gear select shifter thingy. Contact the seller to see if he has the shifter rod that bolts on the side of the TC. Your 249s will not work.
94cherry is offline
