Transfer case,rear seal Repair ????? - JeepForum.com
post #1 of 6 Old 01-09-2012, 10:01 PM Thread Starter
hdrocknroll
So now!! I see My transfer case is leaking at the rear where the rear driveshaft goes in. It is a 231.
Do I remove the rear extension part #38 two replace the seal, or just take out drive shaft and pop seal out,and do I need to replace the bushing #39 also ,or not?? Is this the only seal #40. I need to replace to fix this leak??
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #2 of 6 Old 01-10-2012, 05:15 AM
TallyZJ
Can you just buy the new tail cone assembly already with new parts in it?
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #3 of 6 Old 01-10-2012, 06:20 AM Thread Starter
hdrocknroll
Thanks Tally
I found the Transfer Case Housing Extension w bushing w/o seal, on line for ,34 and 44 dollars
Any suggestions on best place to buy ?
If the bushing is bad it just might be causing the vibration, I have been trying to track down ,What Do you all think ?
post #4 of 6 Old 01-10-2012, 06:16 PM
TallyZJ
I would want a new bushing. If the bushing is worn out that can lead to seal failure.
TallyZJ is offline
post #5 of 6 Old 01-10-2012, 06:22 PM
bigbill888
I am chasing an annoying vibration, too. What is yours like?
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #6 of 6 Old 01-10-2012, 11:17 PM Thread Starter
hdrocknroll
Had to put in very very close to a whole quart of atf in transfer case,to fill it up .
I don't know when it was last checked,I just got Jeep Dec 3rd
Vibration hard to explain, but going say 50 slap in neutral it doesn't change,or any speed ,but is a little more vibration at higher speed
I is all the time ,but not constant,it's like a light vibration, vooba,vooba,vooba
Cant tell where it's coming from, does it going straight or turning
It does feel like a U joint and it could be,but I checked u joints (except at front wheels which I only looked at), no movement in joints,nor did I see any thing wrong.
So!! any one, whats the best way to check u joints
seal leak , transfercase
Average Transfer case repair cost? 5jeep9 ZJ Grand Cherokee Forum 9 03-09-2010 11:57 AM
Transfer Case Seal schu98ZJ ZJ Grand Cherokee Forum 4 05-18-2007 03:14 PM
95 Rear Seal Repair RichB ZJ Grand Cherokee Forum 4 09-12-2006 07:58 AM
97 gc transfer case rear seal help airmech691 ZJ Grand Cherokee Forum 1 09-26-2004 12:12 AM
transfer case seal r&r i hate toyotas ZJ Grand Cherokee Forum 0 06-19-2003 05:10 PM
