transfer case questions 249 - JeepForum.com
post #1 of 5 Old 04-03-2013, 08:13 PM Thread Starter
cumminspwr11
so i swapped my 249 out of my jeep for a 231, then my 241 in my dodge blew up so im trying to see if i can make a good tc out of the 249 and 241, my question is how do you get the front ring for the planet out of the case, i pulled the giant snap ring out but its pressed into the housing, is there a special puller for it?
cumminspwr11 is offline
post #2 of 5 Old 04-03-2013, 08:16 PM Thread Starter
cumminspwr11
oh and im also selling any of the parts i may not need from the two, all the 241 internals are brand new form the dealer and the 249 worked fine, i just wanted a better 4x4 tc and the 2x option, the reason all the 241 parts are new is because i used all my old internals in the new case
post #3 of 5 Old 04-03-2013, 08:28 PM
dnuccio
im gonna go out on a limb and say probably none of the parts are interchangable, but i might be wrong
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #4 of 5 Old 04-03-2013, 09:20 PM
zarnold
Seems like there is another lock ring.
Search "NP249 Disassembly" in this thread:
http://www.jeepforum.com/forum/f13/t...-np242-685644/
zarnold is offline
post #5 of 5 Old 04-06-2013, 05:32 PM Thread Starter
cumminspwr11
thanks for the link, im going to give it a read in a min, i hoped to make a 249 with 2 wheel drive but it doesnt look promising, i can still build a good 241 out of the two, the cases are the same the only problem is that front ring is a different pitch because the 249 is made in 94 and the 241 is a 2000, i could also build the 249 with a 6 pinion front planet instead of the three pinion planet that is originally in it, i will keep you guys posted on what i come up with
