-   -   Transfer Case Problems (http://www.jeepforum.com/forum/f13/transfer-case-problems-1470259/)
furz4 01-28-2013 11:04 AM
Looks like I blew transfer case. It was getting a bit noisey in front, had fluid in diff and transfer case. I thought my noise was the front wheel bearing but it seems it must have been in transfer case. Started to growell and just kept gettiong louder, then I smelled the gear oil and I knew I had a problem. Appears the transfer case had been filled with 90 wt and it oiled me down good underneath. Front wheels will not move when you back up. Looks like I will have to pull driveshaft and hopefully I will be able to move it into garage. what other issues should I be looking for here? Am hoping I didn't mess up the front diff. It was realy lugging down and shaking right before I had to stop. Didn't think 90w was usauall transfer case lube either.
JohnnyZJ 01-28-2013 03:12 PM
jeeps use ATF3..........
furz4 01-28-2013 04:15 PM
That's what I thought, should be interesting to see what kind f carnage is in there once I get it out.
Rich93ZJ 01-28-2013 04:21 PM
It didn't happen unless we get pics :PopCorn:
Technohead 01-28-2013 04:27 PM
I've seen those t-cases run for months bone dry. If it really was filled with gear oil then I doubt that caused your problem. Perhaps the more serious concern it what else did the bonehead who filled it with gear oil do wrong?
Good luck.
furz4 01-28-2013 04:59 PM
Yea she was full of gear oil alright. I am suspecting it had some bearing issues and the 90 wt was an effort to quiet it down some. Am hoping it didn't take out more stuff when it went. Never heard of one going and leaking oil all over fast like this one did. I suspect I will probably find more wrong the deeper in I get. I'll get some pics once I get it back home and into the garage.
furz4 04-24-2013 05:20 PM
Well it's been a while since I posted this and I have finally got it home and into the shop. The good news is the transfer case looks to be ok. The bad news is the front differential pinion bearings are the problem and the cause of the oily mess. Looks like the ring and pinion may be usable, the carrier got chewed a little by the end of the pinion gear but looks like it will clean up ok. I am thinking of just replacing the bearings and races and reassembling with the existing shims and running a pattern and back lash check and see how it looks. I am wondering what my chances of being in the ballpark will be? I could borrow the pinion depth gauge if needed. I would rather not remove the housing if I don't have to. I have messed with gears before with pretty good results but mostly Mopar 8 3/4 stuff which is a lot easier as the center section is removable. I would like to hear from some jeep people in the know as this looks an a lot like the little Mopar 7 1/4 unit and slant sixes would blow them.
furz4 04-28-2013 10:04 PM
Or should I just go ahead and install everything new and be done with it.
speedbucket 04-29-2013 06:42 AM
Just go get a new axle from s salvage or part out. Gonna be much cheaper and faster to swap the whole axle.
On a side note....do you have joint axle shafts or CV axle shafts?
If you need to drive it and have the u joint shafts....remove the joint and use only the outer stub shafts. The lack of inner shafts will keep anything from moving in the housing (with driveshaft disconnected of course). But the outrrz have to be installed to keep the unit bearings together
ratmonkey 04-29-2013 03:19 PM
if the gears came out enough to lock up while driving, they're pretty much trashed now.
The time now is 03:57 PM.
