Transfer Case problem? - JeepForum.com
post #1 of 3 Old 09-03-2003, 01:59 PM Thread Starter
grandjeep
Hey guys, I have a question about my jeep. It is a 95 Grand Cherokee with the 4.0, and it has the selec trac 4x4. recently I have noticed that when I am driving I can hear a clicking from what sounds like the transfer case. When I shift to 4 HI the whole jeep shudders and bangs. Upon shifting back to 2 HI the jeep drives fine but still clicks.
I can feel the jeep shift into 4 wheel drive and coasting everything is fine, it is just when I accelerate.
Any ideas would be very helpful.
Thanks
grandjeep is offline
post #2 of 3 Old 09-04-2003, 01:23 AM
Colorado 5.9
Colorado 5.9's Avatar
Humm?, Could be a bad dearing in the t-case somewhere. It could also be a few teeth are missing on the front out put shaft. Or another one of the shafts. Could be the chain is very worn/lose. It also might not be engaging properly. As you can see, there are a # of things that it could be.
How long has it been since the t-case fluid was changed? The fluid is very easy to check & change.
That's the first thing I would be doing. Then I would go from there if nothing changes.
One other ? Are you engaging it into 4X4 properly?
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #3 of 3 Old 09-04-2003, 12:42 PM Thread Starter
grandjeep
Thanks for the reply, I did check the fluid in the case, it was about a half quart low, I filled it up and it is still making noise. I have had the jeep for many years and have engaged the 4wheel drive before so I am pretty sure I am engaging it correctly.
Thanks for the suggestions, I will look into how to check the chain, because that sounds very reasonably.
-grandjeep
Transfer case problem dethfat ZJ Grand Cherokee Forum 12 04-06-2009 01:14 PM
transfer case problem sickjeep1998 ZJ Grand Cherokee Forum 15 05-07-2008 07:43 PM
transfer case problem zbsadler ZJ Grand Cherokee Forum 0 12-29-2007 10:37 AM
is this a transfer case problem? emptyhead ZJ Grand Cherokee Forum 27 05-04-2006 11:58 PM
94 ZJ Transfer Case Problem -- I think... SMEVERTS ZJ Grand Cherokee Forum 3 08-14-2005 05:59 PM
