transfer case noise? - JeepForum.com
post #1 of 17 Old 12-14-2008, 04:24 PM Thread Starter
nisilvia
I have a 2000 jgc and it makes noise from the middle to the front of the drive train. I did the axle and hub on the passenger side and the drivers side still looks good no oil leaks or anything. I changed all the diff fluids but not the transfer case yet, jeep was closed today, but could it be the transfer case? It makes a sort of a grinding noise and clicking-clanking noise, when i let it drive without stepping on the gas it doesn't make any kind of noise at all but once I step on the gas or slow down the noise comes back. any help would be much appreciated, thanks alot.
nisilvia is offline
post #2 of 17 Old 12-14-2008, 05:14 PM
kmd1776
what engine and transfer case do you have?? if you have 4 all time; N; 4 LOW thats the 247 transfer case. if you have 2wd; 4 full time; 4 part time; N; 4 LOW you have the 242 transfer case
04 wj limited; 4.7L V8, 247> 242hd swap; Hayden auxillary tranny cooler; BFG All Terrain 245/70/17; Moog Up-Country Coil Springs; Monroe Reflex Monotube Shocks; JKS BPE's; Chrome Overland tow hooks; Dynomax Ultraflow catback
kmd1776 is offline
post #3 of 17 Old 12-14-2008, 06:42 PM
cmonson
could be a u joint. Also could be the CV joint if you have that style of driveshaft. U joints are replaced very easily. CV joints can be rebuilt on the driveshaft, or a new one is around $350.
cmonson is offline
post #4 of 17 Old 12-14-2008, 07:39 PM
jeremy18
If you have the CV style driveshaft look at the rubber boots on both ends of it axle end and TC end. When those boots have a small tear it lets all the grease come out and therefor dirt and all other germs get inside the driveshaft causing it to come dry and noisy
99 WJ Black on Black on Black
4.7L V8,20x10 Wheels,33/12.50/R20 Nitto Muddgraplers,6.5" IRO Long Arm Kit,Flowmaster 50 SUV Series Exhaust,4 10" Memphis M3 Sub's In Slot and Port Box,2000 watt Memphis Bell Amp,300 Amp Alterantor,Memphis Amp Kit,5% Tint All The Way Around,Black Projector Lights,Black Projector Fog Lights
jeremy18 is offline
post #5 of 17 Old 12-14-2008, 08:58 PM Thread Starter
nisilvia
I think it is the 247 transfer case. Is there anyway to check the fluids? Well I'm pretty sure I have to change the fluid anyway so that is a must. Is there anyway to check it without taking it apart? I tried to search but no luck. Would it lose power if it was the transfer case? Because it feels so strong after the diff change. I'm not sure if it is a u joint or cv joint driveshaft but you guys think that could be it? I could check that tomoro. If it is it do you think I could drive it to work tomorow and fix it mid week?
nisilvia is offline
post #6 of 17 Old 12-14-2008, 09:02 PM Thread Starter
nisilvia
I have the 4.7 engine by the way. I also remember seeing the rear driver axle be a little bit greasy fro a leak or something. I guess Illl have to replace the too but that cant be the noise right because it doesnt sound like it comes from there. Anyway thank to everyone that replied
nisilvia is offline
post #7 of 17 Old 12-14-2008, 09:35 PM
20jeepwj00
The 247 t-case has a viscous clutch for the all wheel drive,i have seen this cause noise issues in the t-case,if you have any acess to run the vehicle on a lift or with all 4 wheels off the ground listen around the rear of the t-case,if it is loudest in that area the clutch is probably the issue.
20jeepwj00 is offline
post #8 of 17 Old 12-15-2008, 11:56 AM Thread Starter
nisilvia
I just checked out my driveshaft today. they looked okay and they werent cv driveshafts i think because they didnt have the rubber boots on them is that right? there was a leak on the transfer case though. do you think that could be it? My jeep does have 107 thousand miles on it.
nisilvia is offline
post #9 of 17 Old 12-15-2008, 02:40 PM
JG_Canuck
Change out the TC fluid right away. Use only the 247 fluid from the dealer. Go from there.
Canadian Jeep Club Member Forty-Two
JG_Canuck is offline
post #10 of 17 Old 12-19-2008, 12:07 AM Thread Starter
nisilvia
well I'll update you guys with what I did. The good news is that I changed the TC fluid with the TC247 fluid from the jeep dealer, wasn't too bad 29.?? for two quarts. Well after I changed it I took it for a drive, it sounded a little bit better but the noise was definitely still there. There was still some snowy/icy areas on my street so I figured I put each side of the wheels on ice and see how my new tires perform. It helped me learn that the problem was in front of my car for sure. It slips for a little bit then as it grabs it makes a really loud noise while its gripping. So is this the diff? or the transfer case? Sorry for making everything so long just trying to help you understand my problem. As always thanks alot.
nisilvia is offline
post #11 of 17 Old 12-19-2008, 09:15 PM Thread Starter
nisilvia
another thing I had to drive it today because the snowstorm in the northeast and the steering wheel was shaking like crazy.
nisilvia is offline
post #12 of 17 Old 12-31-2008, 01:26 PM
naamang
Does this noise start @ around 40mph and then start getting quieter as you go faster? If so, it's most likely the transfer case. There is a chain that connects the front drive shaft to the main shaft coming out of the transmission. My Jeep had just over 100k miles when mine did this. What happens is the chain gets stretched and hangs loosely under the sprockets. When you get the truck to around 40mph, centrifugal force makes the chain disperse the slack evenly over the the entire perimeter of the chain, causing the chain to loose grip with the sprockets and jump teeth. The faster you go, the less grip it has with the top of the sprockets and the quieter the popping noise gets. Total cost to fix this is around $400 (for the 247 model) if you do the work yourself. The job is not as difficult as you might think. Here is a link to instructions on how to disassemble the transfer case: http://www.ehow.com/how_2179550_disa...sfer-case.html The trickiest part is expanding the snap ring in order to get the tail housing off. I didn't want to have to remove the transfer case from the vehicle to do the job, so I used a pair of needle nose pliers and cut the nose down as well as the handles so it would fit between the snap ring and the under-body of the vehicle. I also ground flats on the outside of the nose so it wouldn't slip off of the ring. You may be able to reuse the sprockets if you haven't been having this problem too long. The chain costs $250 at the dealer. I waited too long to fix the problem so the chain wore the sprocket teeth down. Hope this helps!
naamang is offline
post #13 of 17 Old 12-31-2008, 05:43 PM
Igota94Grand
wondering if this is my problem. I have the all time 4x4 gc. it has 212,000 miles on it. just replaced the cv's the other day. still making the noise you described. aroung 40-45 when you hear it best
Igota94Grand is offline
post #14 of 17 Old 01-01-2009, 03:02 PM
naamang
I have found a much better price of $99 on the transfer case chain (part #: 5012322AB) for the 247 model here: http://www.rigidsteel.com/y159pC3tIGk0.html Sure beats $250 at the dealer!
naamang is offline
post #15 of 17 Old 01-01-2009, 03:45 PM
naamang
The best way to see if the chain is your problem: Secure the vehicle to keep it from rolling away, then remove both front & rear drive shafts from the differentials (leave them attached to the transfer case). Now, with the transmission in Park, rotate the rear shaft and note the amount of play. Now do the same with the front drive shaft. If the front has a considerable amount more play than the back, the chain is your problem.
naamang is offline
Transfer Case Noise ROEDAN ZJ Grand Cherokee Forum 1 01-11-2008 06:40 AM
Transfer case noise? Christina M ZJ Grand Cherokee Forum 2 03-25-2007 07:50 PM
Transfer case noise Whille ZJ Grand Cherokee Forum 1 10-30-2006 08:38 AM
Transfer case noise in 99 limited. T-roy ZJ Grand Cherokee Forum 10 03-14-2006 12:31 PM
Need help please, transfer case noise TGMInd ZJ Grand Cherokee Forum 2 04-26-2004 09:25 PM
