Transfer case lever stuck - JeepForum.com
post #1 of 15 Old 08-07-2007, 03:48 PM Thread Starter
fzillman
Hi all,
I just bought a 01 WJ (with QTII) and the transfer case lever is stuck in 4 All Time. The previous owner said he didn't switch it to 4LO for years - and never took it off road!!
Anyway, I want to get it fixed up and from the reading I've been doing it appears the linkage may be seized up - I tried moving the lever attached to the transfer case underneath manually but it wouldn't move. Not sure if I was at the right thing
Anyway - any one else had this problem? I think I may just need some rust penetration spray and grease it up - but I'm not sure what exactly is seized up.
A picture would be helpful if anyone has a suggestion
Thanks,
Fred AKA n00b
fzillman is offline
post #2 of 15 Old 08-07-2007, 07:12 PM Thread Starter
fzillman
I found this link from a few years ago, but it sounds just like the problem I'm having.
http://www.automotiveforums.com/t237181.html
When he says "the selector rod together with the torque shaft were STUCK in the frame bucket!" - forgive me but - where exactly would I find that. I'm in unknown waters now
Thanks!
Fred - n00b
fzillman is offline
post #3 of 15 Old 08-07-2007, 08:38 PM
Trouble Maker
reckless endangerer
Trouble Maker's Avatar
All that stuff is under the Jeep bolted to the side of the tranny. Just crawl underneath and soak all the linkage you can see with penetrating oil and try working it back and forth.
Or just pick up a piece of "The Rock" and beat it into submission.
Russ
02 Dakota Quad Cab 4.7 5 spd
93 ZJ Stolen and wrecked Mar29/08
Trouble Maker is offline
post #4 of 15 Old 08-08-2007, 02:33 PM Thread Starter
fzillman
I went and checked the TC oil tonight, and it's low. I put my finger inside and couldn't feel a pool of oil - but I could feel the oil in the sides (I just got home). I was planning on changing the TC oil this weekend anyway.
Any by penetration oil - would you recommend WD-40 or something else? Is liquid wrench better?
Rock - what rock ?? I can't see any rocks around here.... oh wait now
Thanks!
fzillman is offline
post #5 of 15 Old 08-08-2007, 06:08 PM
randyszj94
randyszj94's Avatar
1994 ZJ
put ur tranny in Neutral and shut ur jeep off, then try to change it...
sometimes mine gets stuck and thats how i hafta do it..
randyszj94 is offline
post #6 of 15 Old 08-10-2007, 03:17 PM Thread Starter
fzillman
UPDATE: Change the TC fluid today and sprayed some liquid wrench on (what looks like) the lever in question attached to the TC.
I don't have a pic, but its basically a vertical lever with a cable attached to it. Does that go to the shift lever?
I sprayed it and gave it a knock - waited a few min and then repeated with no love. The shift lever still only moves a little bit back and forth.
One thing I noticed today was that there is an orange indicator when movng the shift lever - its actually a bit down (towards N) and I can push it up toward 4 ALL TIME.
Anyway, I'm gonna leave it overnight and see what happens in the morning. Any other comments or suggestions?
Thanks,
Fred
You're only as good as the fuel in your tank - Trailbreaker
2001 Grand Cherokee Laredo, 4.0L, QTII, pretty much stock right now
2006 Pontiac G6 GT, 3.5L V6 with 224 hp
fzillman is offline
post #7 of 15 Old 08-10-2007, 03:35 PM Thread Starter
fzillman
Doing some reading it appears that liquid wrench may take a few applications (and a few days) to works its magic
At least now it wont eat into my drinking time:
http://en.wikipedia.org/wiki/George_Street,_St._John's
"It is understood by locals and those who choose its nightlife as a destination to have the most pubs per square foot of any street in North America"
fzillman is offline
post #8 of 15 Old 08-10-2007, 04:35 PM
ta2oodfreak
ta2oodfreak's Avatar
screw liquid wrench. get pb blaster it works small miracles
96 ZJ
TREC Series #44
ta2oodfreak is offline
post #9 of 15 Old 08-10-2007, 04:43 PM
YJinMN
2007 WK
If you use PB and it sitll is sticking, the problem is elsewhere.
MP
YJinMN is offline
post #10 of 15 Old 08-11-2007, 10:45 AM Thread Starter
fzillman
Hmm - OK
Picked up some PB today and we'll see what happens.
Thanks,
Fred
fzillman is offline
post #11 of 15 Old 08-11-2007, 04:29 PM
CMARJEEP
CMARJEEP's Avatar
im not quite sure about QT but on my 01 with selec-trac, any time you want to shift you have to press down on the shift lever. the handle on it goes down about a half inch and that unlocks it so it can be shifted.
CMARJEEP is offline
post #12 of 15 Old 08-11-2007, 05:02 PM
YJinMN
2007 WK
I've got a QTII, just took it around the block and shifted it into 4lo a few times- I didn't have to push down, (cmarjeep is right, selec-trac you have to push down)and it shifted pretty smooth the whole way back ..
I hope your TC is ok.....
MP
YJinMN is offline
post #13 of 15 Old 08-14-2007, 12:07 PM Thread Starter
fzillman
So - another update on this. The PB hasn't made a difference, so today I took the center console apart to see if there was anything with the shifter.
Here is a picture of the shifter:
The area I have circled in blue - I'd like to pull that off to see I can then move the lever but it wouldn't come off easy -
The lever circled in red won't move - at all.. I have the car in N as the manual says but that black lever won't move. Not even when trying with a pair of pliers there is a bit of give.. but nothing compared to the same black lever on the other shifter:
Here is the other shifter:
And here it is when you press on the handle (as if you were moving into drive)
I can also move that lever with my finger.
So - is that lever in the first pic suppose to move? If so what would you suggest - a bit of lubricant to try and get it moving? What actually makes that lever move back and forth on the TC shift lever?
Thanks!
Fred
fzillman is offline
post #14 of 15 Old 08-14-2007, 05:06 PM Thread Starter
fzillman
Bump - geesh, that went fast
fzillman is offline
post #15 of 15 Old 08-15-2007, 07:09 AM Thread Starter
fzillman
Bump....
fzillman is offline
Help Stuck Transfer Case!!!! 1997zj ZJ Grand Cherokee Forum 10 07-10-2011 04:55 PM
Weird Transfer case Lever problem JagImaging ZJ Grand Cherokee Forum 9 11-24-2009 02:41 AM
transfer case stuck in 4wd? lateralus3 ZJ Grand Cherokee Forum 3 07-18-2009 09:07 PM
Transfer Case Lever Trim Issue? IRPerformance ZJ Grand Cherokee Forum 9 04-30-2008 09:43 PM
HELP! Broken Transfer Case/lever! jrinck ZJ Grand Cherokee Forum 6 02-01-2005 10:50 PM
