Transfer case issues - JeepForum.com
post #1 of 6 Old 04-01-2014, 09:45 AM Thread Starter
aagill225
I am having a humming sound that I think might be the t case. My 98 5.2l has 214k miles and I've never had and issues. We replaces the from ring/pinion because that corrected the problem in the past. This time no go. The sound only occurs when the front drive shaft is installed and goes away when it's removed. Does the VC in the t case make a humming/whirling sound when it's bad?
'99 WJ, 4.7L, completely bone stock, except for 245/65/16 tires
'76 Jeep Grand Waggy, 360cid Edle 660cfm/edle intake Quadratrac
'02 Exterra 3.3L, 5-spd, traded YJ for it :(
'89 YJ 2.5L, 5-spd, Borla header, dynomax super turbo muffler, Big-O XT 30x9.5r15
2004 Jeep Liberty Renagade 3.8L 2wd
'86 XJ 2.8L V6, 5-spd manual tranny (My 1st)
aagill225 is offline
post #2 of 6 Old 04-01-2014, 10:07 AM
PolkaPower
To test if the VC is bad put the front shaft back in and drive it in tight figure 8's with the steering wheel turned all the way. If it feels like it's binding and hopping and you need to give it some gas to get it moving then the VC is bad. It will also leave tire marks on the pavement because the front tires are being dragged.
A bad VC can lead to a bunch of other front steering problems, tire wear, diff issues, ect.
PolkaPower is online now
post #3 of 6 Old 04-01-2014, 10:14 AM
CatSplat
1994 ZJ
Another possibility is that the transfer case's front output bearing is worn out and making the noise.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #4 of 6 Old 04-01-2014, 10:38 AM
PolkaPower
I'm betting that it is if the VC was allowed to go bad for a while before the shaft was removed. Could be the reason the diff was messed up too.
post #5 of 6 Old 04-02-2014, 09:57 AM Thread Starter
aagill225
Yeah I think it's the third time we've had the diff rebuilt. Is it easy to swap a 2wd t care?
post #6 of 6 Old 04-02-2014, 10:00 AM
PolkaPower
No, there is a very large thread at the top of the page about swaps. It's safe to remove the front drive shaft until you get it sorted out but go test to see if it's bad first to be sure.
