transfer case issue? - JeepForum.com
post #1 of 6 Old 05-14-2013, 02:47 PM Thread Starter
ajm3377
got a nice jeep in a trade. 95 Grand Cherokee Laredo w/ 318. all was well for 2 weeks, then it started. the squeaking sounded like the ujoints, so i replaced all 4. some noise went away, but then it got worse. lubed up everything with a zerk i could find. that didnt help anything. fluids look good in both diffs, and transfer case. noise gets worse when i let off the gas. sounds the same whether i use the brakes or not. the last few times ive driven it, it has started to sound like gears slopping. any suggestions? ive been at this a month now, ANY help is greatly appreciated
ajm3377 is offline
post #2 of 6 Old 05-14-2013, 04:44 PM
tucsonzj
does the noise really get worse when you let off the gas or is it just you can hear it better and you're slowing down and less engine noise? Is the sound harmonic or random intervals? When the car is stopped does it still make the noise or only when moving? What about when in neutral either stopped or when moving?
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #3 of 6 Old 05-14-2013, 06:49 PM
paintballwannab
Could also be your double cardan joint in the front driveshaft. Mine was making squeaks and causing vibes.
paintballwannab is offline
post #4 of 6 Old 05-14-2013, 08:31 PM Thread Starter
ajm3377
it gets worse, its harmonic, only when the vehicle is moving, makes the sound whether its in drive or neutral, also happens in reverse
ajm3377 is offline
post #5 of 6 Old 05-14-2013, 08:36 PM
tucsonzj
Yea check drive shafts first
tucsonzj is offline
post #6 of 6 Old 05-15-2013, 12:41 PM Thread Starter
ajm3377
that was indeed what it was. thanks for the help guys!
ajm3377 is offline
drivetrain , transfer case , transmission
