Transfer Case Grinding? - JeepForum.com
post #1 of 10 Old 10-22-2009, 02:58 PM Thread Starter
GrandLaredoWJ
I went on a hunting trip lately where i had to use 4WD a lot.. while i was out there i started to hear a god awful grinding noise coming from somewhere ONLY when it was in 4WD. now it is real bad to the point where i can feel the grinding coming from somewhere when i slip it into 4WD. It doesnt make any noise when im in 2WD at all and it works fine other than that. I would like any opinions on what you guys think it is. Thanks!
'00 Grand Cherokee/Rally Jeep-Ojibwe Forests Rally Heavy Sweep #95 -4" Teraflex Lift, Homemade Adj. Longarms, 33x10.50 BFG All Terrains, 4.2L built, bored, blueprinted & balanced, Lots more..
Red Jeep Club Member #499
MN Jeeper #48
Black '75 CJ5- Built 304, 4.88's, Dana 44 Spooled, Dana 30 Spooled, 4" lift, 35x12.50 tires
GrandLaredoWJ is offline
post #2 of 10 Old 10-22-2009, 03:18 PM
Bama_WJ
Bama_WJ's Avatar
See if an adjustment in the shifter cable will help.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #3 of 10 Old 10-22-2009, 03:34 PM
gomes512
1994 ZJ
If anything first thing I would check is the fluid level in the tcase. If low, I would drain and see what comes out. Look for any metal debris, discoloration and smell.
gomes512 is offline
post #4 of 10 Old 10-22-2009, 03:48 PM Thread Starter
GrandLaredoWJ
Forgot to add.. I changed the fluid in it before i left on the trip. Didnt find anything unusual then...although it was working great before i changed it. i put about 1200 miles on it since the change.
MN Jeeper #48
post #5 of 10 Old 10-22-2009, 05:13 PM
ras2001wj
ras2001wj's Avatar
Off topic, but you don't have a 45rfe, you have a 42re transmission
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
ras2001wj is offline
post #6 of 10 Old 10-22-2009, 05:49 PM Thread Starter
GrandLaredoWJ
i have the 45rfe.
MN Jeeper #48
post #7 of 10 Old 10-22-2009, 07:21 PM
sandman
i would start by unbolting the linkage and shifting it manually at the t-case. most likley its a linkage issue.
1993 Jeep ZJ. 4.0
sandman is offline
post #8 of 10 Old 10-22-2009, 08:26 PM Thread Starter
GrandLaredoWJ
The thing is though (that i should have added sorry) is that is still goes into 4WD.. i didnt think it was locking in at first but when i put it into 4WD the front tires will spin in mud...could it just be slipping in and out? for some reason i think the chain is slipping inside of the T case.
MN Jeeper #48
post #9 of 10 Old 10-22-2009, 09:30 PM
Falkon
Originally Posted by GrandLaredoWJ View Post
i have the 45rfe.
They only come w/ the V-8. Your profile says I-6.
Falkon is offline
post #10 of 10 Old 10-22-2009, 10:18 PM
ras2001wj
ras2001wj's Avatar
Jeep Grand Cherokee WJ - Transmission service and maintenace
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
Nv 247 transfer case making grinding/poping noise nicecj7 WJ Grand Cherokee Forum 27 03-20-2015 05:40 PM
2000 grinding noise from transfer case? doc538 ZJ Grand Cherokee Forum 3 03-21-2009 02:16 PM
Grinding Noise in Transfer Case rflem550 ZJ Grand Cherokee Forum 4 11-03-2005 06:39 PM
Transfer Case Grinding Noise Astorm WJ Grand Cherokee Forum 4 03-21-2004 09:06 PM
transfer case shifting: gear grinding chris_eh ZJ Grand Cherokee Forum 2 03-07-2003 07:24 AM
