Transfer case fluid type - JeepForum.com
post #1 of 11 Old 09-07-2004, 04:45 PM Thread Starter
JohnnyCash
JohnnyCash's Avatar
I just replaced the seal that attaches to my TC and front drive shaft and wanted to know the type of fluid I should put into the TC. Its for a 97 GC Laredo 4.0L transfer case # 242. I called Jeep and they told me I need about 2 quarts of ATF+3, but when I asked the local parts dealer, they said Mercon III. I'm confused, which is it?
JohnnyCash is offline
post #2 of 11 Old 09-07-2004, 06:08 PM
laphan
ATF +3.........
laphan is offline
post #3 of 11 Old 09-07-2004, 07:44 PM
ShadMan
The transfer case uses Dexron III/Mercron, not ATF+3. Everything I have ever read (including Haines) says Dexron III/Mercron for the transfer case and ATF+3 or ATF+4 for the tranny.
Capacity is 2.9 pints, or about 1.5 quarts.
'94 JGC Laredo (ZJ), 4x4, 4.0L, 42RE, Select-Trac
ShadMan is offline
post #4 of 11 Old 09-07-2004, 08:21 PM
Meerkat
Well, since Jeep and Iaphan both told you ATF+3 and ShadMan said Mercon/DexronIII, I imagine you are still feeling confused, so I have to weigh in and support ShadMan on this one. ATF+3 goes in your transmission (1994 and later) and Mercon/DexronIII goes in your transfer case. If you get them mixed up, you'll soon know about it because your transmission will (in technical terms), puke itself.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #5 of 11 Old 09-07-2004, 09:26 PM
laphan
HTH
OK, I just rechecked my owners manual again (its 1998). This what the manual says:
selec-trac - 3.0 US pints / 1.4 liter
Mopar Automatic Transmission Fluid or equivalent labeled Dexron III or Mercon.
I guess anykind of tranny fluid should work for 242 t-case. I asked the dealership and they says ATF+3 or 4 thats what I use on mine.
laphan is offline
post #6 of 11 Old 09-07-2004, 09:45 PM
Dalmask
I'll pitch in another vote for Mercon III. I love how Jeeps have nearly every type of fluid known to man amoung their various parts.
-Dal
Dalmask is offline
post #7 of 11 Old 09-07-2004, 09:51 PM
Meerkat
You know, I must have read my 1996 owner's manual about a bazillion times and still had to read it 3 more times after your post before I finally made the connection that Mopar Automatic Transmission Fluid is ATF+ and picked up on the word 'or' in there.
That being the case, the next time I change my TC fluid, I'm going to use ATF+ so it matches the transmission. Unfortunately, my XJ uses Mercon/DexronIII in the transmission and TC, so I will still have to buy the stuff.
Thanks for pointing that out!
Warren
Meerkat is offline
post #8 of 11 Old 09-07-2004, 10:31 PM
ShadMan
I really don't think it would make a difference either way. Owner's manual for my '94 ZJ states:
TC - Mopar Automatic Transmission Fluid or equivalent labeled Mercron or Dexron II.
Tranny - Mopar ATF Plus (Type 7176) is preferred.
Notice, the tranny says ATF Plus, while the TC says ATF. I really don't think it matters, though. It's only 1.5 quarts, so you're not looking at a big price difference if you want to use ATF+3. Personally, I'll just stick to what the owner's manual says.
ShadMan is offline
post #9 of 11 Old 09-07-2004, 10:48 PM
Meerkat
Mercon Automatic Transmission Fluid is for Ford, Lincoln,Mercury
Dexron Automatic Transmission Fluid is for General Motors
I think the way the owner's manual (fairly) consistently uses the name ATF+3, then suddenly stops and simply refers to ATF+ as Mopar Automatic Transmission Fluid merely adds to the confusion.
I think DC has continued the AMC tradition of using different parts from different manufacturers in fine fashion.
Warren
Meerkat is offline
post #10 of 11 Old 09-07-2004, 10:54 PM
ShadMan
You're definitely right about that! Keep in mind that the TC is a NP/NV, not a DC, so DC stating ATF+ is just a way they can make a few extra bucks. The NP/NV 242 was not built with ATF+3 in mind.
ShadMan is offline
post #11 of 11 Old 09-08-2004, 09:07 AM Thread Starter
JohnnyCash
JohnnyCash's Avatar
I purchased the 2 quarts of Mopar ATF+3 (type 7176) from the dealer. I should be good to go.
WJ NV247 transfer case oil change type? Chandler ZJ Grand Cherokee Forum 12 07-02-2013 02:47 PM
Transfer case fluid type cyberZJ ZJ Grand Cherokee Forum 7 12-17-2009 11:22 PM
what type of transfer case does my car have Amer83 WK Grand Cherokee & XK Commander Forum 4 01-13-2009 09:39 PM
What type of fluid in the transfer case? akarusso ZJ Grand Cherokee Forum 6 09-29-2005 03:45 PM
Synthetic ATF, Transfer Case Fluid, Diff. Fluid shel3702 ZJ Grand Cherokee Forum 1 07-05-2004 08:21 PM
