Transfer Case Confusion - JeepForum.com
post #1 of 5 Old 04-03-2004, 02:05 AM Thread Starter
djorkboy
djorkboy's Avatar
I have a 96 Limited that comes (here in Australia at least) standard with the Quadra-Trac transfer case. I cannot find any detailed info on this transfer case.
Web searches found me lots of info on the 'Quadra-Trac I' and 'Quadra-Trac II' transfer cases fitted to WJ models, but are either of these the same as the Quadra-Trac as fitted to the ZJ Grand Limited??
Is my Quadra-Trac permanent 4x4 or is it on-demand? how does it distribute power?
Any info anyone could provide will be greatly appreciated.
djorkboy is offline
post #2 of 5 Old 04-03-2004, 03:00 AM
Interloper
Interloper's Avatar
this may help, clicky
You have a NP or NV 249, it's more of a progressive 4wd system where power is transfered when slippage occurs, never had one myself so I can't be of much help there.
P.S. 242's ROCK!
1995 ZJ Limited. 4.0L
"nobody cares what's underneath," ...Dieter Zetsche
Interloper is offline
post #3 of 5 Old 04-03-2004, 03:22 AM Thread Starter
djorkboy
djorkboy's Avatar
Thanks for that info, it helps to clarify things a bit. I'm still searching for more info. Does my transfer case distribute power to the diff with the most traction or is it not that advanced?
I had heard that there was a better transfer case for real off-road stuff, the 242 sounds like the one. From the info I can find about the 242 it has 2x4, 4x4, 4x4 locked and 4x4 low. Is that correct?
From everything I can see the 242 will just pretty much bolt in without modification?
djorkboy is offline
post #4 of 5 Old 04-03-2004, 01:43 PM
Harald
Hello down under! Have a look at this site: http://www.jeep.com/4x4/index.html?c...epage&type=tab
If you want to swap a TC, pls. look here:
http://www.duff.ws/grand_central/tc_..._case_swap.htm
Think what you are looking for is the 242.
Harald is offline
post #5 of 5 Old 04-03-2004, 09:44 PM
Swamp Boy
Swamp Boy's Avatar
Here is a writeup I did on the 242 swap.. Its not very hard ...
I did it in one afternoon... Literally I started at 12:30 and finished it at about 7 pm... With one person helping...
242 swap linky...
Just another soccer moms Grocery getter....
Swamp Boy is offline
NP 242 Transfer case help J33pst3r ZJ Grand Cherokee Forum 2 03-10-2008 08:27 PM
T-case confusion stageninja ZJ Grand Cherokee Forum 1 05-10-2007 03:35 PM
transfer case fluid confusion 241comp ZJ Grand Cherokee Forum 11 08-30-2005 10:43 AM
Transfer Case/VC RonsWS6 ZJ Grand Cherokee Forum 4 09-08-2004 06:06 AM
transfer case JoshGC4 ZJ Grand Cherokee Forum 5 09-03-2004 05:54 PM
