Transfer case buying question - Page 2 - JeepForum.com
post #16 of 27 Old 06-12-2013, 01:49 PM
dnuccio
Originally Posted by OverlandZJ View Post
"Case" as in housing or the transfercase as a whole?
Reason I ask, i'm about to assemble a 242-249 hybrid using the 249 front housing. I'm also going to look into the possibility of using the 249's chain and associated gear/output also. Just wondering which if any parts are stronger..
you could be onto something here. i still have my 249 from when i did the swap. i would be very interested in beefing up the 242 with parts from the 249., if it will work. can anyone clarify?
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #17 of 27 Old 06-12-2013, 03:39 PM
ejschultz
ejschultz's Avatar
I'm fairly positive the answer is no. It's been gone over before.
01 TJ - 4.0L, NV3550, 2" Skyjacker budget boost, Xenon flat flares, Trail Gear front bumper, 33" STT Pros on 15x8s
ejschultz is offline
post #18 of 27 Old 06-12-2013, 03:44 PM
tucsonzj
I think you can do a chain swap, or was that into the 231, with the 249 chain and some other parts, but that's it IIRC
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #19 of 27 Old 06-12-2013, 03:58 PM
PolkaPower
The 242 HD for the WJ has the same chain as the 249 I think. From what I have read you should be able to swap some parts between the 242HD and 242 to make it stronger.
If I was going to buy one it would be from George http://www.transfercase.com/
PolkaPower is online now
post #20 of 27 Old 06-12-2013, 09:51 PM
chetzar
1994 ZJ
I just bought one from George, he's a great guy answered all my questions and never once pressured me to make an order. I'm planning on swapping in my 242 this weekend (he specifically does 249-242 or 249-231 for ZJ's, and requires no core return).
I'll post some pictures of mine this weekend, I opened the box and it looks like used case half's, but new internals.
chetzar is offline
post #21 of 27 Old 06-12-2013, 11:04 PM
StridAst
1994 ZJ
I bought one from george as well. Installed it a couple weeks ago. Really simple to do when he sends it with the input shaft already swapped. Internals are largely from the wj 242. So you aren't getting the weaker 242 chain. A bit pricy though. Around 830 shipped iirc and no core return.
StridAst is offline
post #22 of 27 Old 06-13-2013, 12:34 AM
chetzar
1994 ZJ
Also, if you want to keep the 249, but want it to function better, he builds a 249/247 Hybrid.
chetzar is offline
post #23 of 27 Old 06-13-2013, 10:26 AM
OverlandZJ
Is this George somebody here? jrmechanic maybe?
OverlandZJ is offline
post #24 of 27 Old 06-13-2013, 11:01 AM
Jeeples
Jeeples's Avatar
^ George is the guy who runs the transfercase.com website IIRC.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #25 of 27 Old 06-13-2013, 11:25 AM
StridAst
1994 ZJ
Yep. Definately the best place to go, if you choose to spend more that you would spend at a junkyard.
StridAst is offline
post #26 of 27 Old 06-13-2013, 08:57 PM
MN59ZJ
Originally Posted by tucsonzj View Post
Same can be said for 249 haters...don't be jealous because my chains thicker and case is stronger. Lol
I'm not, because it isn't! Don't be jealous of my custom built 242hd with a stronger chain than a 249, 6 planetary input, 32-spline output with a SYE. ;-)
And I don't hate the 249. They're a good case if the operator wants to put up with the disadvantages.
Sent from AutoGuide.com Free App
MN59ZJ is offline
post #27 of 27 Old 06-13-2013, 09:00 PM
MN59ZJ
Originally Posted by ejschultz View Post
I'll quote myself from another thread... These numbers are all taken from a NP/NV transfer case chart. The transmission ratio was obtained from numerous sites. Both the 42RE and 44RE have the same gear ratios. Strength is a moot point. Yes, it's stronger, but for what purpose?
That's very sensible, and far more pragmatic than most people who get in to these weeds ever will admit.
MN59ZJ is offline
