transfer case or axle u joints - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > transfer case or axle u joints
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEG2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ ChTJ Wrangler 4" Rough Country Suspension Lift Kits in
Unread 12-06-2014, 09:25 PM   #1
93zjgrand
Only in 4 wheel drive do I have problems.. while driving in muddy wet grass straight or turning I get this pop or chirp noise every few seconds... never in 2wd.. the dana 35 always spins in 2wd right just not engaged and I don't think it's anything on the inside.. could it be the ujoint on the axle or the transfer case... how to check each it you could/can.. the drive shift has no play and feels solid.
93zjgrand is offline   Reply With Quote Quick reply to this message
Unread 12-07-2014, 12:36 PM   #2
neonhomer
What transfer case do you have? I'm assuming the 242. Sounds like maybe the double cardan joint in the front driveshaft might be getting worn. (From what I was told by Tom Woods Custom Driveshafts) If you take the driveshaft off, the double cardan should stay up, not just flop down.
Try changing the fluid in your t-case. Two quarts of Mopar 7176 +4 (ATF +4... DON'T USE DEXRON/MERCON or GEAR OIL!) will do it.
Your u-joints might need lubrication. If you have grease fittings, give them a shot of grease. If not, you might need to pull the shaft and check the caps to see how they rotate.
[COLOR="Lime"][SIZE="5"]NeonHomer[/SIZE][/COLOR]
Mid-Florida Jeep Club - Member
1996 Jeep Grand Cherokee, 4.0L/42RE/242 - Rebuilt motor w/ Comp cam (4/12), 3.5" Junkyard F>R lift, 31x10.5.x15 M/T's, Spartan Locked D44a, TC & tank skids, F&R adj trackbars, V8 steering arms
Galaxy DX99V CB, 102" SS Whip, Yaesu FT-2900R 2m, Larsen 1/4w mag mount, Sony HU, Massive 3way - F Door, Pioneer 3way - R Doors, MB Quart ONX304 Subs (x2), Lanzar 1600w amp.
"No Matter Where You Go... There You Are."
"Oh me oh my a lovely day is dawning. Oh what a joy I didn't wake up dead. So I can go to work and then resume my yawning, and get my sleep on site instead of in my bed" - Daria Morgendorffer (with my twist)
neonhomer is offline   Reply With Quote Quick reply to this message
Unread 12-07-2014, 12:43 PM   #3
93zjgrand
I have the np231.. I also have to give it more throttle than normal in 4 wheel... my front drive shade spins all the time.. but don't do it in 4 wheel
Unread 12-07-2014, 02:40 PM   #4
durango-bob
I would start by checking the front axle U-joints. After that the front driveshaft joints. Finally it could be the chain in the t-case that has worn and stretched.
durango-bob is offline   Reply With Quote Quick reply to this message
Unread 12-07-2014, 04:01 PM   #5
93zjgrand
How do you check the ones on the on axle itself.. I looked under the Jeep and the drive shift were it sides in and out and the coupler is a little loose.. but the joints feel solid
Unread 12-07-2014, 07:19 PM   #6
durango-bob
The way I do it is to jack up the front end, turn the steering wheel and then rotate the tires and watch the u-joints. You will see wobbling and binding if they are bad.
