Transand tranfer case replacement 96 zj - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Transand tranfer case replacement 96 zj
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerraiThe Original 3/8" Ruffstuff Diff Cover!
Unread 04-24-2015, 07:20 PM   #1
soxfan1129
My freind blew the trans on his zj, he wants to sell it for super cheap, next to nothing, it has a 5.2 and headers on it, 180 k miles, how hard is a trans replacement on these, while I'm at it I would like to swap it from quadra drive to selec trac, is that a straight forward swap too, or is it pretty complex, I am pretty mechanically inclined and have swapped the trans on a cobalt and it was a pain in the ***, would this be easier since it's a conventional trans, does the motor have to come out to swap it?
Thanks
soxfan1129 is offline   Reply With Quote Quick reply to this message
Unread 04-24-2015, 07:50 PM   #2
DKARM
The 242 swap is very simple. There is a great thread on here that you can follow that walks you through the whole process. I'll try to find the link. I'm not sure about the tranny though.
ZJ 5.9 w/ 31s and some bolt ons
DKARM is offline   Reply With Quote Quick reply to this message
Unread 04-24-2015, 07:54 PM   #3
DKARM
Here is the write up I followed. It's very in depth.
http://www.jeepforum.com/forum/f13/t.../topics/685644
Unread 04-24-2015, 09:15 PM   #4
Kolby_with_a_K
1994 ZJ
Swapped my Trans without taking the motor out. Pull the zj up on 4 ramps, took out both driveshafts, put a jack under the Trans got the weight off crossmember, took out crossmember, removed the bolts holding bell housing and torque converter, let the Trans down with the jack. I would recommend taking transfer case off first though it adds alot of weight to the Trans and I wouldn't try and do it by myself. It took 3 of us to take mine out, but we're just backyard mechanics
Kolby_with_a_K is offline   Reply With Quote Quick reply to this message
Unread 04-25-2015, 07:38 AM   #5
soxfan1129
Ok thanks, I was looking at the procedure and it looks pretty straight forward, he wants 100 bucks for the jeep so i think I'll do it, what do used transmissions usually go for on these, this is just going to be my backup car and my off-road toy since I already daily a wj
