trans temp gauge-keep blpwing up cunverters - JeepForum.com
post #1 of 2 Old 02-22-2003, 09:25 PM Thread Starter
scubatch2
Has anyone installed a trans temp gauge.I keep overheating and blowing up converters.I was told that stalling the conv. during off-raoding builds up to much heat,therefore over heating converter.I have the factory trans cooler but I thought a temp. gauge may help me keep an eye on it.Any other idea's.just saved up for lookers,know $700 blown on replacing conv. and blown seals.
95 zj 5.2,Re 4.5+3/4in spacer,456's,true-trac frt,trac-lock rear,Hanson rockers,33"MTRs,surco,hella's,high-lift,flow-masters&cat,ax&shovel mounted on rack,onboard air,231 swap,Hanson front & rear bumper,ford elec fan
- jeff-
scubatch2 is offline
post #2 of 2 Old 02-23-2003, 03:16 AM
ChrisinVA
Holy smokes, I thought I was the only one having these problems. No one would believe me when I said not having torque converter lockup would overheat the thing, but here I am, getting my tranny overhauled. They found some wire in the harness that grounds against the body and keeps it from locking up.
This won't help your situation any, but just letting you know someone else out there has a similar situation.
ChrisinVA is offline
Temp Gauge calibration AL P ZJ Grand Cherokee Forum 7 02-22-2007 10:04 PM
temp gauge, fan not working HELP! fiddlyD ZJ Grand Cherokee Forum 16 01-19-2006 09:28 AM
Trans temp gauge phasewolf ZJ Grand Cherokee Forum 1 06-10-2005 09:51 AM
Trannie temp gauge mcmark ZJ Grand Cherokee Forum 1 03-06-2005 01:19 PM
Temp Gauge bradmere ZJ Grand Cherokee Forum 5 02-15-2005 05:57 AM
