Trans swap...how much time? - JeepForum.com
post #1 of 4 Old 07-02-2013, 08:42 PM Thread Starter
Dumpy
1972 J-Series Truck
42RE is going out and time to swap. I have a trans jack and everything else ready to go, just no garage and a lot of rain in the forecast. About how long should I expect the swap to take, and is there anything I need to look out for or take into consideration?
Also, and problems removing the exhaust?
'96 ZJ
'72 Jeep J2000 Pickup
Dumpy is offline
post #2 of 4 Old 07-02-2013, 08:52 PM
dnuccio
i have the 46RH, but probably not much different other than its bigger. pulled it to replace the pump seal. i had access to a lift. took me around 6 hours. it was my first time pulling and installing a trans.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 4 Old 07-03-2013, 10:33 PM
KBUCK
1997 XJ Cherokee
Be sure to take out the crank sensor before removing the bell housing bolts or you could break it. The crank sensor is on the top of the bell housing at the block mating surface and just to the right of center. It has 2- 13 mm headed bolts holding it in. After you take the bolts out lift it straight up its about 3 inches long. I have put 5 transmissions in my 97 and it now takes me about 1.5 hours to complete the job. I found it is easier to take the transfer case off before removing the trans. I actually don't use a jack for it, it only weighs about 30 lbs.
KBUCK is offline
post #4 of 4 Old 07-04-2013, 08:31 AM Thread Starter
Dumpy
1972 J-Series Truck
Cool, thanks. I have the crank sensor down to an art form. Was thinking about pulling with the tcase off. I've done manuals but only installed one auto in a Wagoneer. This thing is way heavier than a 727!
'96 ZJ
Dumpy is offline
