trans swap - JeepForum.com
post #1 of 3 Old 11-04-2013, 10:09 AM Thread Starter
greenjeepkeegan
1994 ZJ
trans swap
Ok so the trans is going out on my 94 zj limited. So i plan on buying a new one from a jy. But was also looking at putting the manual trans in it. Has anyone done that and if so how hard was it
greenjeepkeegan is offline
post #2 of 3 Old 11-04-2013, 05:49 PM
shaban
Junkyard trannys: anything from another ZJ or WJ will fit, WJ's require some fitting and sensor swapping but thats easy.
Putting a manual is a big pain, you'd be better off buying a car with one installed.
ECU will have to be changed at least, plus some major fabbing to get the clutch pedal, shifter stick etc.
AX-15 is the manual that came with ZJ's, but only in 1993.
shaban is offline
post #3 of 3 Old 11-04-2013, 07:48 PM Thread Starter
greenjeepkeegan
1994 ZJ
Alright thanks i appreciate the feed back
