Trans over Temp light come on and P0740 code - JeepForum.com
post #1 of 9 Old 04-20-2008, 12:36 AM Thread Starter
luigi120
Hi there, its my first time posting.... i have a Wj 2" lift kit with 31" tires .... recently when i go in open highway for more than an hour drive the check engine light come on and then the trans over temp light come on too and the fan run faster than normal.... i wait 5 min to the trans over temps light goes off to drive again.... I took out the code and P0740 its the code that it gave .... any help i dont know what to do?
luigi120 is offline
post #2 of 9 Old 04-20-2008, 12:47 AM
WiLieR
Need more info. Year of jeep. Engine size.
99 WJ Laredo - Mine once again!
WiLieR is offline
post #3 of 9 Old 04-20-2008, 01:06 AM Thread Starter
luigi120
Wj 2001 , 4.7 L, 45RFE transmission
luigi120 is offline
post #4 of 9 Old 04-20-2008, 08:07 AM
JeepOrvis97
JeepOrvis97's Avatar
Torque Converter Clu No RPM Drop at Lockup
Relationship between engine and vehicle speeds indicated failure of torque convertor clutch lock-up system (TCC/PTU sol).
Got this from wjjeeps.com, is the fluid low?
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
post #5 of 9 Old 04-20-2008, 12:32 PM Thread Starter
luigi120
that is the P0740 description (Torque Converter Clu No RPM Drop at Lockup Relationship between engine and vehicle speeds indicated failure of torque convertor clutch lock-up system (TCC/PTU sol).) but what i have to do to repair it? what do i need to change to avoid the light come on?....
and the fluid its ok. I change the fluid and filter thinking it can solve the problem but it didint... and the light come on again.
luigi120 is offline
post #6 of 9 Old 04-25-2008, 07:22 AM
JeepOrvis97
Ok, it looks like you need a scan tool for the following test... I would take it to a good transmission shop if I were you because Automatic transmissions are a pain to work with.
P0740-TORQUE CONVERTER CLUTCH CONTROL CIRCUIT
When Monitored and Set Condition:
When Monitored: During Electronically Modulated Converter Clutch (EMCC) Operation.
Set Condition: Transmission must be in EMCC, with input speed > than 1750 RPM. TCC-L/R Solenoid achieves the maximum duty cycle and can not pull engine speed within 60 RPM of input speed. Also when the transmission is in FEMCC and the engine slips TCC > than 100 RPM for 10 seconds.
POSSIBLE CAUSES
RELATED DTC P0750 PRESENT
INTERMITTENT WIRING AND/or CONNECTORS
INCORRECT FLUID LEVEL
INTERNAL TRANSMISSION PROBLEM - TCC OUT OF RANGE
L/R SOLENOID INOPERATIVE
Current jeeps:
1997 ZJ Orvis
post #7 of 9 Old 08-17-2009, 07:35 PM
slegerjr
1989 XJ Cherokee
I have just now started having the same kind of problem with my 2002 cherokee limited. I changed the filter and fluid today. When I got on the highway to take my son home, The trans overe temp light and the o/d off light came on. When I pulled over to check the fluid level, I noticed a little smoke coming ont of trans dip stick. Now I know this can't be good. Has anyone else ran into this problem before. I really dont have the money for this type of problem right now. I dont know what to do. H E L P Please.
I found something on the internet about a recall from 99 to 04 models that mentioned there was not enough flow of fluids through the transmission. Is there anyway to have jeep dealer fix this recall or are there guidelines to recalls. Is there a expired time period that I would have to worry about?
Last edited by slegerjr; 08-17-2009 at 07:39 PM. Reason: didnt say everything I wanted to say
slegerjr is offline
post #8 of 9 Old 10-25-2010, 10:54 AM
Kevin5097
i too have the same problem, (posted on another page). I have a 03,GC 6 Cyl. Wonder how many more of us are victims???
Kevin5097 is offline
post #9 of 9 Old 11-26-2010, 08:17 AM
gordon
2003 WJ
I too have the same problem, after towing my boat on the HWY for an hour. (WJ GC 2003 4.7 v8 45RFE). P0740 comes on and this time Trans Temp alarm light comes on too. I pulled over and after 5 mins of idle the trans cooled down and I drove home more gently with no problems. I also checked the tranny fluid and it looked to be at the right level.
After reading on this forum I am going with the theory that I may have fluid flow issues due to possibly dodgy cooler lines. Fluid flow/low fluid pressure being limited could cause a) Tourque Converter Unable to lock up b) Transmission to overheat.
I also noticed some spots of fluid on my boat trailer, which also points to a tranny leak. After work I will get under the car and have a look.
At best this may be new cooler lines along with a beefier cooler, fluid and filter change. At worst it could be a new/rebuilt tranny :-(
gordon is offline
O/D and trans temp light coming on-- is this bad? w00ten WJ Grand Cherokee Forum 17 04-01-2011 08:11 PM
Transmission Code P0740 stratons_yj ZJ Grand Cherokee Forum 4 01-20-2010 07:17 PM
P1757 & P0740 code- What do I need to replace? 96stroker ZJ Grand Cherokee Forum 0 06-04-2009 07:40 AM
2001 WJ Trans Over Temp Light boldknight ZJ Grand Cherokee Forum 4 10-01-2006 05:38 PM
Trans Temp Sensor: Code 45 TurboXJ ZJ Grand Cherokee Forum 2 02-05-2005 11:44 AM
