Trans leak - JeepForum.com
post #1 of 6 Old 04-10-2013, 03:57 PM Thread Starter
93jeepwag
Trans leak
Got a leaky Transmission, Leaks a fair amount when it sits for long periods of time. Seems to start leaking hours after it sits. Anywho, my first jeep and I know nothing about them. Can anyone tell me where all the trans can be leaking from. The whole trans is covered in fluid from the front to back.
Front meaning by the engine to the trans and on the T case.
What are all the locations for possible leaks? Trans seal....what else?
Might as well check them all. Oh its a 93 grand wagoneer 5.2 qaudra whatever. 44re I think.
93jeepwag is offline
post #2 of 6 Old 04-10-2013, 04:30 PM
PolkaPower
46RH is the trans from 93-95 v8's. Take a look at where the transmission lines go into the radiator on the passenger side. There are plenty of spots it can leak from. The lines going to the rad, the transmission pan, the lines going into the trans, ect. You just have to wipe it all clean and then examine it closely.
PolkaPower is offline
post #3 of 6 Old 04-10-2013, 04:50 PM
dnuccio
Clean the whole trans real good with brake cleaner, then check it often to see exactly where its leaking from.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #4 of 6 Old 04-10-2013, 06:45 PM Thread Starter
93jeepwag
Will do, is there not a seal that it could be leaking from?
post #5 of 6 Old 04-10-2013, 07:35 PM
alivenkickin28
The lines going into the radiator usually start leaking at the quick disconnects. It could be blowing back or check the seals at either ends of driveshaft and see if those are leaking.
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
post #6 of 6 Old 04-12-2013, 10:19 PM
KoreaZJ
1994 ZJ
Mine had same symptoms when tranny front pump seal leaked.
Scrape off caked crud, wipe everything clean like dnuccio suggested, then keep watch where the leak starts from.
KoreaZJ is offline
