Trans or front end skips when accelarating or turning?? New to Jeeps - JeepForum.com
post #1 of 7 Old 09-30-2009, 10:26 PM Thread Starter
grokee318
Ok i got a 98 ZJ Full Time 4wd. When i either goose it or turn and accel it makes a grinding noise and it makes the trans skip. But at other times it is just fine. it only does it under 25mph. I am new to the whole jeep thing and just seeing if anyone has had any problems like this with there ZJs? Thanks
grokee318 is offline
post #2 of 7 Old 09-30-2009, 10:49 PM
sandman
possibly sounds like a failed viscous coupler.
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 7 Old 09-30-2009, 11:00 PM Thread Starter
grokee318
yeah the more and more i search it sounds like what it is. Anyone know where i can find one for a good price? This is my only vehicle so i gotta get it done quick. Thanks for the reply
post #4 of 7 Old 09-30-2009, 11:23 PM
sandman
a transfer case swap is what your looking at. i paid $50 for mine but got lucky, if i were you i wouldnt pay over $200 for a used t-case.
1993 Jeep ZJ. 4.0
sandman is offline
post #5 of 7 Old 10-01-2009, 12:11 AM
sean924
viscous couplers=about 400 for a part that has already failed on you once. just bought a t-case out of a 99 cherokee today for 100 bucks. i have the same year grand with the same transfer case. if you go the route of a new transfer case, i would look for either an np231 or 242. im assuming you have a 5.2l v8, with a 44re transmission(i know the tranny code may sound like jibberish to you) if you do have the 44re, you will need a 23 spline input shaft, not a 21 spline. it was discussed in a previous thread as well. from what i have gathered here and elsewhere on the internet, they made the switch from he 21 to the 23 spline in 95. so as long as you find a 23 spline 231 or 242, you should be fine. someone please correct me if i am wrong on this. oh, there is also a write up on how to do the case swap in the FAQ section of the zj/wj tech forum. may want to check that out if you have not done so already. hope this helps
98 ZJ, IRO 5.5" critical path. 33x12.50x15 KM2's, 15x8 soft 8's, alpine system, radio shack CB, PA speaker.
Firefighters Jeep Club
sean924 is offline
post #6 of 7 Old 10-01-2009, 12:22 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
The 21 spline tcase was only found on early cherokee and wrangler(yj) 4cyl models it was phased out in 91 I think.
You're thinking of the planetary gear pitch change in 95.
ratmonkey is offline
post #7 of 7 Old 10-01-2009, 09:11 AM Thread Starter
grokee318
Thanks alot, you guy have been very helpful i have seen the write up on doing the swap and am more then likely going to do that as soon as i get my garage organized so i can get the jeep in. Thanks agian
auto trans shifts from 1st to 3ed skips 2ed gear protozee ZJ Grand Cherokee Forum 0 08-01-2009 08:41 AM
97' skips around corners Mikekunath594 ZJ Grand Cherokee Forum 34 05-19-2009 01:20 PM
Trans skips over 2ed gear protozee ZJ Grand Cherokee Forum 0 10-16-2008 03:17 PM
Air wont flow through vents when accelarating or going up hill loup1276 ZJ Grand Cherokee Forum 4 07-01-2008 08:41 AM
front end turning noise..? H0miegwillikers ZJ Grand Cherokee Forum 13 08-06-2007 02:09 PM
