Trans Fluid Type 99 Grand Cherokee 4x4 - JeepForum.com
post #1 of 9 Old 12-30-2006, 06:46 AM Thread Starter
srode
2008 XK Commander
Getting ready to change the trans fluid in my 99 Grand Cherokee 4x4, but don't know what type to use. ATF3? Dextron 3? Looking for regular fluid, not synthetic. Suggestions?
2008 XK Commander Limited 4.7 Quadra Trak II
1999 Jeep Grand Cherokee 4x4 Quadra Drive 4.7 L 163,000 miles(sold)
2004 GMC SLT Crew Cab 4x4 Duramax Diesel
1969 Camaro Pace Car
1969 Camaro Hard top
91 Cherokee - sold at 188,000 miles, still runing great at 250k last report
srode is offline
post #2 of 9 Old 12-30-2006, 07:01 AM
rm2001wj
rm2001wj's Avatar
There is only one fluid recommended for the 45RFE transmission behind your 4.7L: Mopar ATF+4 or ATF+4 made by one of the Chrysler approved manufacturers like Valvoline. Using anything else means that you are experimenting with a very expensive piece of machinery.
ATF+3 was designed for pre-99 transmissions and has been superseded by ATF+4.
rm2001wj is offline
post #3 of 9 Old 12-30-2006, 07:17 AM
greasefingers
greasefingers's Avatar
1994 ZJ
The AFT+3 is not synthetic. AFT+4 is. ATF+4 cost $ 4.19 to 4.69 per qt for Valoline.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 9 Old 12-30-2006, 07:57 AM Thread Starter
srode
2008 XK Commander
thanks for the quick response guys! Is the ATF +4 safe for the 1999? I saw it wasn't safe for 1999 Dodge minivans, something compatibility with the seals. I know synthetic isn't compatible with some seals and will cause leaks. Takes about 9 quarts for the pan and filters right?
srode is offline
post #5 of 9 Old 12-30-2006, 08:32 AM
MSU.WJ
MSU.WJ's Avatar
Yeah, the '99 has the same tranny as the other years, so use ATF+4. 9 quarts sounds about right. I lost count when I did mine.
2000 WJ Laredo 4.7 NP242
3" Lift, 31" MT/Rs, Aussie Locked D44A, JKS sliders, more
Want places to wheel? Support the Blue Ribbon Coalition:
MSU.WJ is offline
post #6 of 9 Old 12-30-2006, 08:48 AM
greasefingers
1994 ZJ
I drained mine overnight and only got 4 qts out of her. I would purchase 6 just to be safe.
Cheers Steve
post #7 of 9 Old 12-30-2006, 08:58 AM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
Only 6 drained out of mine... DON'T OVER FILL.... add SLOWly untill full.
2013 FR-S
BlaineWasHere is offline
post #8 of 9 Old 12-30-2006, 09:04 AM
greasefingers
1994 ZJ
You also need a small Torx key/wrench to remove the filter. I cannot remember if it was a T15 or a T25
Cheers Steve
post #9 of 9 Old 01-26-2014, 11:48 PM
Shintodragon
FYI the transmission filter screws are T25
Shintodragon is offline
98 Grand Cherokee TRANS problems JpeeGRDCHER ZJ Grand Cherokee Forum 11 09-16-2008 01:07 PM
97 Grand Cherokee Trans Hell robbysk8er1 ZJ Grand Cherokee Forum 3 09-09-2006 06:27 AM
WG Grand Cherokee Trans problems HYP-047 ZJ Grand Cherokee Forum 3 03-20-2006 04:06 PM
94 Grand Cherokee Trans?? grizz ZJ Grand Cherokee Forum 2 03-26-2005 09:01 PM
What type of CD changer can I put in Grand Cherokee 97 ? D.V. ZJ Grand Cherokee Forum 1 08-20-2002 03:36 PM
