Trans dip stick leaking bad ! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Trans dip stick leaking bad !
USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire Carrier
Unread 05-22-2014, 10:07 AM   #1
fishermandave95
Dono if any y'all have talked about this b4 but wana ask any how
So i had a 1000$ 1000 man hrs night mare of a tranny rebuild that had my trans in and out 8 dam times ! But she sexy and gangster now with fresh guts , new converter and a port job , and all lowerd a lil for my lift
All this sead and done im still leaking really bad from the dip tube where it gose into the trans , have chaged the o ring gasket 4 times trying to fix this
Any ideers on how to fix this ? My tec buddy sead a gasket from a chevy should work seens its a cone type , what do y'all think
fishermandave95 is offline   Reply With Quote Quick reply to this message
Unread 05-22-2014, 10:57 AM   #2
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Yea, the tube needs to slide down into the trans quite a bit. At least 1/2". Had the same problem. The tube/brackets were bent (not by me, but by the POS mechanic I took it to), not allowing the tube to be inserted far enough into the trans.
HighLonesome is offline   Reply With Quote Quick reply to this message
Unread 05-22-2014, 12:15 PM   #3
fishermandave95
Its just the dang seal , i did all the work so I know it dint get bent , we are just having a hell of a time with the o ring and finding a new one or better up grades
Unread 05-22-2014, 12:18 PM   #4
HighLonesome
If you are sure the tube is going down far enough then must be the wrong o-ring.
Unread 05-22-2014, 12:22 PM   #5
fishermandave95
Ya guss ill have to coff up the 3$ and 4 day wait from dealer , we have tryed a fu different ones from parts store that says its right and still leaks , ill ask my tec buddy what gasket he thinks will work that he told me about
Unread 05-26-2014, 08:43 AM   #6
Billyjoebob007
Here ya go:
Auto Trans Dipstick Tube Seal ATP TO-53
http://www.ebay.com/itm/310710464571...%3AMEBIDX%3AIT
Billyjoebob007 is offline   Reply With Quote Quick reply to this message
