tranny or torque converter - JeepForum.com
post #1 of 4 Old 08-27-2003, 07:51 AM Thread Starter
98 Sport
I have a 98 GC with the 4.0l and select trac (I think that's the one---awd, 4wd hi, 4wd low). Lately I've noticed that I'm having some problems when I'm cruising at a constant speed. This happens when I'm driving with and without cruise control.
Anyway, when I'm cruising at highway speeds, I notice that sometime the car hesitates like it's going to downshift and the rpms go up very slightly, again, like it's about to downshift, then the rpms go back down and nothing else happens.
Anyone know if this is a tranny or torque converter problem?
98 Sport is offline
post #2 of 4 Old 08-27-2003, 09:38 AM
automan25
It sounds transmission related to me. Torque Converters are practically indestructible anyway. Have you checked your trans fluid recently using the method outlined in the owners manual? Have you replaced the fluid and filter in your transmission. These are the two easiest and cheapest things to try first.
SelectTrac by the way has full-time, part-time, 2WD, and part-time low modes. If your 4WD system is 4WD all the time with no 2WD mode available, then you have QuadraTrac.
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
post #3 of 4 Old 08-27-2003, 06:58 PM
JEEPTECHNICIAN
Will the cruise work thru this complaint? Or does it quit working when this happens. you may have a bad brake pedal switch or a bad torque converter lock uo solienoid or a bad converter.
JEEPTECHNICIAN is offline
post #4 of 4 Old 08-28-2003, 03:14 PM Thread Starter
98 Sport
Yeah, it keeps on cruising. The cruise control doesn't turn off or anything. Also, like I said, it happens when i'm driving w/o the cruise contral as well.
98 Sport is offline
94 ZJ: rebuilt 4.0 low output, Refurb Tranny Torque converter rubbing ytudrepus ZJ Grand Cherokee Forum 6 04-22-2010 07:23 PM
Tranny either slipping in OD or torque converter coming out of lock up? crashcraddock ZJ Grand Cherokee Forum 20 07-23-2009 12:19 PM
Torque Converter ? JEEPOLD ZJ Grand Cherokee Forum 2 12-12-2008 04:16 PM
Help with torque converter daytondb ZJ Grand Cherokee Forum 0 12-26-2007 01:11 PM
torque converter automan25 ZJ Grand Cherokee Forum 2 11-22-2003 01:43 PM
