tranny/tc seal questions - JeepForum.com
post #1 of 6 Old 07-26-2009, 08:40 PM Thread Starter
gharris54
My 2000 dub has been leaking a couple drops a day of tranny fluid where the trans meets the tc for a while but it sat in the garage all last week and when I got back it had leaked probably a half quart on the floor.
My first question is where is the fluid comming from, I know some is comming from the trans but could some of it be from the transfer case? I know there is an output seal on the 42re but is there also an input seal on the front of the 242?
Second, how hard is it to change the seals and would I need any special tools(like wierd pliers or punches)? Do you just drop the tc and thats it or would it be easier to just keep adding fluid?
2000 dubya jay, IRO 3'' and 265/75R16 bighorns, quicker discos, custon spring retainers, custom ford 9'' rear end with the stock wj discs
Dana35 SOLID diff cover and a lock-right locker for a Dana35 for sale
gharris54 is offline
post #2 of 6 Old 07-26-2009, 09:42 PM
Virmagicus
Virmagicus's Avatar
I have actually seen were both seals went bad and the TC literally filled up with ATF. The big puddle is indeed coming from your tranny if it is coming out the weep hole where the TC and tranny meet.
Jeff
Virmagicus is offline
post #3 of 6 Old 07-28-2009, 08:32 AM Thread Starter
gharris54
yeah so there is an input seal on the tc?
post #4 of 6 Old 07-28-2009, 11:05 AM
tsconver
2003 WJ
yes there are seals on teh output of the tranny and the input of the tc. Easy to replace, just unbolt teh driveshafts, and remove teh 6 nuts holding the tc tothe tranny. Disconnect the wiring to the tc and the shift linkage and lower it with a jack. It is heavier than it looks. I had mine out in 15 minutes to do my hack n tap. Probably 30 min to put it back just because I decided to manhandle it putting it back in.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #5 of 6 Old 07-28-2009, 08:25 PM Thread Starter
gharris54
ight sounds good, so I dont need and weird tools to change the seals? sounds good, i'll probably change the tc fluid too while im at it
post #6 of 6 Old 07-28-2009, 09:14 PM
Virmagicus
Virmagicus's Avatar
You can buy a seal puller or what i do is drill a small hole in the seal itself and use a dry wall screw to pull the seal out. Just try not to mar the surfaces around the seal with a screwdriver or anything like that.
Jeff
seal between tranny and T-Case? KINGOFTHHILL ZJ Grand Cherokee Forum 2 07-05-2009 04:55 PM
Please Take A Look At These Tranny Shaft Pix, Seal Leaking drizler ZJ Grand Cherokee Forum 4 05-16-2008 11:38 AM
Front Tranny Seal Removal??? drizler ZJ Grand Cherokee Forum 0 05-03-2008 03:24 PM
Leaky Tranny Seal justjeepin ZJ Grand Cherokee Forum 5 03-31-2006 08:18 PM
Tranny Seal Leak jeepholic ZJ Grand Cherokee Forum 10 08-10-2004 08:02 PM
