Tranny question - JeepForum.com
post #1 of 15 Old 07-27-2011, 01:57 PM Thread Starter
Muddy97
Tranny question
I checked my tranny fluid and its a little dark and kinda smells burnt it has 220k on it for a 97 should I flush and replace the filter and stuff or just add some fluid
Muddy97 is offline
post #2 of 15 Old 07-27-2011, 02:00 PM Thread Starter
Muddy97
Sorry for double post also what would be the best oil for my i6?
Muddy97 is offline
post #3 of 15 Old 07-27-2011, 02:14 PM
classicmetalman
Fill out your profile or list specs of vehicle, helps people know what your working on/talking about.
I'd drop the pan, change the filter, and top off with fluid. Drain and refill in a couple of weeks, should have all new fluid. If your not having any shifting issues, you should be good to go. I'd add a drain plug, you'll find out why.
By oil, I assume your talking bout trans fluid ATF+4
Robert
93 Laredo 4.0
96 Limited 4.0
Originally Posted by murphydajeep View Post
I say you should still hit something just to let it know you mean business, or shake a hammer at it in a menacing fashion
classicmetalman is offline
post #4 of 15 Old 07-27-2011, 02:21 PM Thread Starter
Muddy97
Thanks and by oil I mean motor oil I'm not sure what to run in it. It's the 4.0 I6
Muddy97 is offline
post #5 of 15 Old 07-27-2011, 02:22 PM
Erbo1Kanerbo
hehe tranny question
ZJ Build thread:
ZJ's: If you dont know what it is you cant afford it.
Erbo1Kanerbo is offline
post #6 of 15 Old 07-27-2011, 02:28 PM
sabzz
Either change your filter and fluid yourself, or go get it serviced and checked out. I'm only saying spend the money because my tranny went out back in march and I've only got 181k on the clock and its a 97 I6 too. We had never changed the fluid/filter in it since we've owned it, last time I ever make that mistake. Once I get it fixed I'll definitely start changing filter and fluid on it regularly!
1998 ZJ 4.0 work in progress/DD
'97 ZJ 4.0|3.5 RC|31" -SOLD
sabzz is offline
post #7 of 15 Old 07-27-2011, 03:16 PM Thread Starter
Muddy97
How often should it be changed the PO didn't really keep up with it
Muddy97 is offline
post #8 of 15 Old 07-27-2011, 03:26 PM
sabzz
Eh. Thats really up to you to decide when you want to change it I guess. Once I get my transmission fixed, I'll be changing the fluid on it probably once a year, just for the heck of it and give me some peace of mind.
sabzz is offline
post #9 of 15 Old 07-27-2011, 06:34 PM Thread Starter
Muddy97
Ok thanks all for the advice
Muddy97 is offline
post #10 of 15 Old 07-27-2011, 07:14 PM
phitmein
phitmein's Avatar
you could also adjust the tranny bands while you have the pan off ...
Edit: link from the Stickys section ... http://www.jeepforum.com/forum/f13/t...ml#post2765400
phitmein is offline
post #11 of 15 Old 07-27-2011, 07:24 PM
sabzz
I know this is probably a stupid question, but what exactly are bands and what do they do? I got the same problem with my tranny except i have to floor it to get it to move and even then it doesnt. I'm sure my tranny is shot because the fluid is black, but doesn't smell burnt or anything.
sabzz is offline
post #12 of 15 Old 07-27-2011, 07:37 PM Thread Starter
Muddy97
I would like to know also.
Muddy97 is offline
post #13 of 15 Old 07-27-2011, 09:25 PM
phitmein
phitmein's Avatar
here are some good reads ... look for the band stuff ...
http://www.familycar.com/transmission.htm
Phit
phitmein is offline
post #14 of 15 Old 07-27-2011, 09:49 PM
gothchick
An external auxiliary tranny cooler definitely wouldn't hurt either...
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
post #15 of 15 Old 07-27-2011, 11:14 PM Thread Starter
Muddy97
Ok thanks
Muddy97 is offline
