Tranny Problems!!!!!!!!!help!!!!! - JeepForum.com
post #1 of 7 Old 08-28-2004, 08:32 PM Thread Starter
hellrazor
The other day, I was driving and gave it some gas and all of sudden it reved but didnt really go anywhere. And right at that momment the check engine light came on. I proceided home very slowly and pulled in the drive way. I put it in 1st and gave it some gas and it jumped like it should. And 2nd was fine to. But when I put it in drive and gave it gas, it rev'ed up and bearly moved. Please tell me this is some kind of sensor or pressure switch, and not a screwed tranny.................Any help is greatly appreciated............
Thanx, Branden
hellrazor is offline
post #2 of 7 Old 08-30-2004, 10:30 PM
boredinocala
Same Exact Tranny Problem Started Today!!!
My 02JGC 4.0 started doing the same exact thing today. Have you found anything out yet? Feels like it's starting out in 3rd gear because it never shifts. Manually goes into all gears. Most likely a valve body or governor problem.. What do you think??
boredinocala is offline
post #3 of 7 Old 08-31-2004, 12:18 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
HR,
do you have a Haynes or Chilton's manual? If not get one and do the check engine check codes to see what is wrong. With the limited info you gave, it could be as simple as a clogged fuel filter, or the distributor and wires going bad.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 7 Old 08-31-2004, 12:44 PM
Buddha_Kip
Buddha_Kip's Avatar
No need for a manual...it's most probably the "output torque thrust sensor". mine went out a couple months ago, and the symptoms were exactly as razor described his. I'm not certain if you can replace this yourself....it was covered under warranty on my truck, so I just let the dealership change it out.
2000 WJ Limited - 2.5" Rusty's springs WAAG 1-piece front brush guard custom built WAAG nerf bars PIAA 580 lighting Custom Paint One-off Aluminum Treadplate Door Entry Guards & Rear Bumper Step
1986.5 Porsche 928S - 18" Moda MD1 Autothority Chips Rear Muffler Bypass Short-Shift Kit
Grease Monkey & HNIC @ Clasik Auto
Buddha_Kip is offline
post #5 of 7 Old 08-31-2004, 04:55 PM Thread Starter
hellrazor
I know yours was covered under warranty, but do you recall how much the parts or labor would have been???
post #6 of 7 Old 08-31-2004, 05:31 PM
treats
If it is stuck in third it's most likely in "limp mode" where the trans see's a problem and leaves it in third. If this is the case the problem may be electical. It's common for the solenoid pack to go haywire on WJ's . part $250 , diagnose and repair approx$300.
Good luck - Treats
treats is offline
post #7 of 7 Old 09-11-2004, 11:37 PM
boredinocala
Mine is a 2002 4.0 automatic. OK , I figured it out. My check engine light never came on when the tranny messed up (trans trying to start off in 3rd). My problem was intermitent. Usually happened at least once a day. Didn't matter hot or dead cold, no warning, just did it. After remembering that "you can't fix it if it ain't broke" I patiently waited for it to do it constantly (I always manually shifted so I wouldn't burn it up when I felt it drop to 3rd when stopped. I could tell because it would't hardly go when you let off the brake). Last week on the way to work it did it every time, nows my chance. I pulled it in the shop and dropped the pan - clean. I figured it was a stuck shuttle valve or a clogged solenoid screen. I removed the solenoids and used a scribe to push the shuttles in the valve body back and forth -THAT"S IT!! The second one back had a tight spot, worked free manualy. Put it all back together and it has not come back yet in 200 miles. YEAY. Crap this fluid is expensive! I'm a mechanic, for Ford, but I'm not going to drive one. Jeep RULES!!! Total cost -$40.00 for 6 quarts of mopar OEM trans fluid. (pan gasket reusable)
ZJ: Still having tranny problems Rickyb ZJ Grand Cherokee Forum 7 12-16-2009 06:07 PM
96 tranny problems? jeeptorino68 ZJ Grand Cherokee Forum 1 11-22-2007 12:18 PM
Tranny problems? SWDoodle ZJ Grand Cherokee Forum 3 09-26-2007 12:48 AM
ABS and tranny problems with my 96 ZJ jon4_48195 ZJ Grand Cherokee Forum 1 09-18-2005 10:50 PM
Tranny problems Devious WJ Grand Cherokee Forum 1 09-22-2002 05:32 PM
