Tranny issue; Gov sensor/solenoid or??? - JeepForum.com
post #1 of 6 Old 02-01-2013, 08:07 PM Thread Starter
zachjf
Ever since I've owned my 5.9 I've had a weird issue during full throttle 1-2 upshifts where the transmission wont shift quick enough to keep the engine from hitting the fuel cutoff/rev limiter so it bucks and sputters, this is a different sputter than the "less than 1/4 tank around corners" fuel starvation issue tho. Up until now I've just dealt with it and either dont give it full throttle or I just back off a bit right before redline then hammer it back down and I'm fine on the 2-3 shift and into O/D. I'm not getting any codes, the tranny doesnt "hunt" gears at partial throttle and the fluid was changed like 10k ago and looks/smells good so I'm wondering if its still possibly a gov sensor/solenoid issue or if I should be looking elsewhere?
Needs parts?
PM
or
zachjf is offline
post #2 of 6 Old 02-01-2013, 09:14 PM
newfieZJ
I think a little tweeking with that throttle cable and you'd be golden . IIRC , move it a notch or 2 back for quicker shifting .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 6 Old 02-01-2013, 09:47 PM
4Slow9erHybrid
adjusting the bands might help as well...
1997 JGC Laredo 4.0 4x4 99900mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline
post #4 of 6 Old 02-01-2013, 09:49 PM Thread Starter
zachjf
Yea, I forgot to mention I've tried that, both loosened it up till it was shifting really early up and down as well as tightened so every gear banged even at part throttle and it was annoying to drive. I'm honestly at a loss since the setting I have it at now results in firm but not rough up/downshifts and the tranny shifts great everywhere except full throttle on the 1-2
Needs parts?
PM
or
zachjf is offline
post #5 of 6 Old 02-02-2013, 09:43 AM
4Slow9erHybrid
You need to adjust the bands.
http://www.jeepforum.com/forum/f13/t...09/index3.html
post #6 of 6 Old 02-03-2013, 01:17 PM
Spanovich008
if it's not throwing any codes, then it's probably not the Pressure Sensor and/or Solenoid. Sounds like your bands need adjusted.
don't be afraid to put the "fun" in "dis-functional"
Spanovich008 is offline
