Tranny issue - JeepForum.com
post #1 of 11 Old 06-09-2013, 01:36 PM Thread Starter
moose27
Tranny issue
So the other night I had a ignition draw off fuse blow causing my jeep to basically shut down. Today it felt like my tranny was slipping. Once I hit 50 it would jerk alot like it was doing the Harlem shake down the road and my gauges started flipping out. Does anyone have any kind of advice for me?
Build: http://www.jeepforum.com/forum/f13/mooses-jeep-build-1456174/
moose27 is offline
post #2 of 11 Old 06-09-2013, 04:14 PM
JasonStebbins
I would disconnect the battery for an hour and see if the reset resolves the problem.
Then check all the fuses/relays in the PDC under the hood.
What fuse blew causing the shut down? The ASD?
Poop
JasonStebbins is offline
post #3 of 11 Old 06-09-2013, 04:18 PM
Rich93ZJ
Sounds PCM related since your gauges were all over the place. Have you checked your PCM connections. Also check for a short (02 Sensor) is the most common. That will take out the fuse as well. G/L. (Harlem Shake)
Rich93ZJ is offline
post #4 of 11 Old 06-09-2013, 04:25 PM Thread Starter
moose27
No that's what I thought it was but it's just a 20 amp fuse for the ignition draw off
moose27 is offline
post #5 of 11 Old 06-09-2013, 04:26 PM Thread Starter
moose27
Yeah my check engine light is for a o2 sensor so I'm going change that out
moose27 is offline
post #6 of 11 Old 06-09-2013, 04:27 PM Thread Starter
moose27
The o2 sensor was hanging down beside the drive shaft so I moved it up out of the way and I've been driving it around and not a single problem yet
moose27 is offline
post #7 of 11 Old 06-09-2013, 04:30 PM
JasonStebbins
CPS could cause weird gauges too.
Check the wiring on both oxygen sensors, front and rear. The rear one can get wrapped around the drive shaft and the front one can get burned on the exhaust.
If one of the sensors blew a fuse, it likely fried the PCM. Let's hope it wasn't this.
Poop
post #8 of 11 Old 06-09-2013, 04:35 PM Thread Starter
moose27
Yeah I hope not :/
moose27 is offline
post #9 of 11 Old 06-09-2013, 04:35 PM Thread Starter
moose27
How can I tell if the PCM is fried?
moose27 is offline
post #10 of 11 Old 06-09-2013, 04:50 PM
JasonStebbins
Well you said the sensor fixed your problem this far.
If your PCM was fried it probably wouldn't run/would run like crap.
Poop
post #11 of 11 Old 06-09-2013, 04:54 PM Thread Starter
moose27
That's what I figured and it's been doin great knock on wood so I dodged that bullet... Hopefully
moose27 is offline
