07-14-2012, 10:39 AM
#1
I am getting a tyranny flush at this very moment and then I am off to get the lube needed to do the diffs and tc myself. What do I need to buy? I am sure that there is a tonne of info but I am limited on time to research.
Thanks. Its greatly appreciated.
1997 Jeep Grand Cherokee Limited
Kelowna, BC
07-14-2012, 10:42 AM
#2
don't do a flush.
4" Rough Country Series 2 lift kit with steel radials 33x12.5x15 on d windows
iro rear adjustable track bar, carolina driveline u joint front driveshaft
replaced transmission at 162k with a junkyard one that had 102k.
07-14-2012, 10:45 AM
#3
I hope you aren't getting an actual transmission flush...I hope you mean just a pan drop, change filter and gasket, put new fluid in. For the TC, ATF+4 is the fluid. All depends on what you do with your Jeep for the differentials. If you tow, use 75W-140 Synthetic or something similar. 90W for just daily driving.
07-14-2012, 10:46 AM
#4
Ohhhhh snap. I did the flush.
Kelowna, BC
07-14-2012, 10:50 AM
#5
A transmission flush can easily kill a Chrysler transmission....
07-14-2012, 10:52 AM
#6
Siiiiick news. It will be fine.
Kelowna, BC
07-14-2012, 10:57 AM
#7
A flush can ruin any transmission with high miles on it. That's just the chance you take.
98 5.9 2"BB, Custom V-Tec mod, high performance muffler elves, alloy performance lug nuts, super high flow custom radiator cap, Ultralight unobtanium flywheel, stage 6 ultralight hydro tuned wiper blades(front), kevlar stickers
[QUOTE=JohnnyZJ;13325401]if its to tall for her to get into why don't you just install some running boards?[/QUOTE]
[QUOTE=HAMAR;13330720]I just gave her ironing board, she's not getting another board.[/QUOTE]
"What is best in life?
"To crush your enemies, see them driven before you, and to hear the lamentations of the women."
07-14-2012, 10:59 AM
#8
90000 miles high?
Kelowna, BC
07-15-2012, 10:38 AM
#9
why is a flush bad?
I have two older cars I've done fluid swaps on. I didn't do an active flush but drained or pumped out fluid a gallon at a time and topped up with a gallon of new. Rinse and repeat for a total of two gallons.
95 Mercury Tracer
95 Subaru Legacy
both at or above 200,000 miles
In both cases I got a distinct improvement in tranny performance. With the Mercury it fixed the occassional slippage I'd get. In the Subaru it fixed the Torgue Bind in my All Wheel drive.
I've heard the warning not to change fluid in an older tranny but it's never been explained what the issue is.
07-15-2012, 11:29 AM
#10
Never heard that but im not a fan of power flushing trannys
07-15-2012, 11:44 AM
#11
Noob question, what's the harm in flushing a trans? You'd ultimately think it'd clean it up a bit no? I can understand something like an engine + seafoam application that will remove that residual grime at certain points in the block that are healthy (figuratively speaking), but I suppose I don't see it in a transmission setting.
07-15-2012, 11:46 AM
#12
I have a thing about disturbing the junk that has found a nice quiet place to live while the tranny is being used.guess im just weird that way
07-15-2012, 11:48 AM
#13
Well. The trans is running great and my MPG have gone up by 3 so far. Now its time for the front and rear difs and tc. There are not any places open today that have AMSOil so its getting a different full synthetic. Suggestions?
Kelowna, BC
07-15-2012, 11:55 AM
#14
Any name brand will suffice
07-15-2012, 11:56 AM
#15
Go to Oreilly's and get their store brand synthetic. Cheaper and just as good. Unless you have to have the magic name brand.
