Tranny-To flush or not to flush? - JeepForum.com
post #1 of 6 Old 05-07-2009, 07:26 PM Thread Starter
craddock01
1996 ZJ Fluid was real dirty,shifting OK except a little slip when cold first shift of the morning. Changed filter and fluid panwise today would like to change out fluid via hillbilly driveway flush procedure but I'm hearing flushes can do strange things to tranny like kicking up crud needing rebuilt soon thereafter,anyone have problems or input?
craddock01 is offline
post #2 of 6 Old 05-07-2009, 07:29 PM
mgramann
I would "slowly" change the fluid... Change the pan in a few weeks again, then again a few weeks later. It will slowly introduce new fluid and be less "shock" to the system.
mgramann is offline
post #3 of 6 Old 05-07-2009, 07:43 PM Thread Starter
craddock01
I hate the thought of that black stuff mixed with the nice red stuff
post #4 of 6 Old 05-07-2009, 07:49 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Doing a flush is no different that the conditions your tranny sees every day when you drive it.
You are using the tranny pump to drain and replace the fluid. This is in no way harmful to the tranny.
Wheelin98TJ is offline
post #5 of 6 Old 05-07-2009, 07:55 PM
mgramann
Did the fluid smell burnt? I know that sometimes if you put new tranny fluid in a tranny that is on its last leg, sometimes you are better off leaving the burnt, less efficent fluid in the tranny. Thats why I suggested a slow change. If the tranny is good a flush shouldn't hurt it though.
mgramann is offline
post #6 of 6 Old 05-07-2009, 07:58 PM Thread Starter
craddock01
Thanks guess I'll go for it see what happens maybe I'll save the old fluid and if it starts acting up I'll put it back in.....
Tranny flush ZJ bubsta ZJ Grand Cherokee Forum 22 07-24-2007 01:08 PM
Tranny Flush Question UofOJeeper ZJ Grand Cherokee Forum 3 03-31-2007 10:13 PM
DIY tranny flush SBlackfoot ZJ Grand Cherokee Forum 19 12-15-2005 06:08 AM
Tranny Flush AsianJKim ZJ Grand Cherokee Forum 6 10-09-2005 05:56 PM
Brake fluid flush and fuel injection flush ArloGuthroJeep ZJ Grand Cherokee Forum 8 05-25-2005 07:46 AM
