Tranny Dying... Now what? - JeepForum.com
post #1 of 18 Old 05-23-2013, 09:12 PM Thread Starter
eagsc7
1994 ZJ
My Transmission is getting ready to die. It's a 42RE, and I'm in the hunt for another one. The question that I have. Without changing out the entire engine, is there a "better" automatic tranny that I could drop right in there.
If you have a recomendation, Please explain to me Why.
eagsc7 is offline
post #2 of 18 Old 05-23-2013, 09:13 PM
Afdude88
What engine?
1993 Grand Cherokee Limited 4.0L AW-4
1998 Grand Cherokee:
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
post #3 of 18 Old 05-23-2013, 11:23 PM Thread Starter
eagsc7
1994 ZJ
Same one as in the Specs. Engine: 4.0 Inline 6
eagsc7 is offline
post #4 of 18 Old 05-24-2013, 12:31 AM
shaban
AW-4 from an early ZJ or a Cherokee. Great tranny, almost bulletproof, but will require extensive hacking to wiring and possible persistent check engine light on OBD2 ZJ's.
42RE from a WJ is a tad better, using deeper tranny pan, newer governor solenoid & some other improvements (band friction material). Least hassle here.
AX-15 manual is another option but involves severe hacking (new clutch pedal etc)
44RE and 46RE are not going to fit due to different bellhousing (V8) , but the internals from 44RE are heavier duty and can be stuffed in 42RE.
That's pretty much all you can swap in, as far as I know.
Myself, I just put another 42RE from a WJ, had to change the neutral switch and the cooler line fittings.
shaban is offline
post #5 of 18 Old 05-24-2013, 06:27 AM
Afdude88
Cant see specs on the phone app.
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
post #6 of 18 Old 05-24-2013, 11:26 AM Thread Starter
eagsc7
1994 ZJ
Ahh Yes.. Using the Mobile app alot myself I realize this is the down side with it! *Maybe a Feature Request for the Mobile app*
eagsc7 is offline
post #7 of 18 Old 05-24-2013, 01:30 PM Thread Starter
eagsc7
1994 ZJ
eagsc7 is offline
post #8 of 18 Old 06-15-2013, 04:51 AM Thread Starter
eagsc7
1994 ZJ
Well, Getting a tranny built from transdepot.net, and their service has been GREAT! Course, the tranny isn't here yet, BUT I called them with a question before buying and they were really knowledgeable. I got a call yesterday saying that the tranny was leaving their shop today, and that I needed to check another connector. 15 Minutes later, we figured out that the connector in the 94 ZJ is one of 2 DIFFERENT TYPES! The connector directly behind the shift linkage (with the same orientation) has a bunch of wires coming out of it. It's either round OR rectangular. Oii! That Piece of )*(!$@(!#$ is REALLY hard to even feel due to my muding and previous oil and other leaks. Of course, the "Strong as Steel" Ramps that BROKE I returned, and haven't replaced with Actual steel. Course, I'll Prolly buy a welder and some scrap from "around" and make some Really tall ramps.
eagsc7 is offline
post #9 of 18 Old 06-15-2013, 05:24 AM
Technohead
The original one presumably lasted 19-20 years. How much better do you want?
-Eric
Technohead is offline
post #10 of 18 Old 06-15-2013, 02:03 PM Thread Starter
eagsc7
1994 ZJ
30-40 years, and 1Million miles...
Out Jeepin, usin the Mobile App
My Build Thread: http://www.jeepforum.com/forum/f13/steaks-zj-build-repair-thread-1552698/
eagsc7 is offline
post #11 of 18 Old 06-15-2013, 02:25 PM
dylantheheeler
We can dream can't we?
Sent from AutoGuide.com Free App
yo vivo. yo voy. yo soy. Jeep.
I live. I ride. I am. Jeep.
dylantheheeler is offline
post #12 of 18 Old 06-15-2013, 04:29 PM
dusterdude
A 727 would last that long
dusterdude is offline
post #13 of 18 Old 06-15-2013, 10:06 PM Thread Starter
eagsc7
1994 ZJ
Yes, we can. The lotto is coming to WY and I'll br the first 30Mil winner too!!!
eagsc7 is offline
post #14 of 18 Old 06-15-2013, 11:28 PM
AVR2
I can attest to that. They can survive levels of neglect that would kill most Jeep trannys much sooner. When I got my ZJ, the trans fluid was black and smelled horrible, and must have been like that for at least a year or two. I drained and refilled it a few times to cycle the old fluid out, and it lasted me a further three years of daily use before finally dying.
AVR2 is offline
post #15 of 18 Old 06-16-2013, 05:32 AM
shaban
One quick note here: if using AW-4, install a tranny cooler! For some reason, AW-4 run hot, much hotter than other trannys, so extra cooler will prolong trannys lifetime and oil durability.
shaban is offline
