Tranny/Diff. fluid & Audio - JeepForum.com
post #1 of 10 Old 10-21-2013, 04:05 PM Thread Starter
95GCL
Hey everybody. As I am starting being able to get more progress on my 95 5.2 I was wondering if I should change my trans fluid and diff fluid. It has 203k miles, has sat for the past two years. So far going through the record log I just got of the jeep, the tranny fluid appears to last have been checked on at 170-177k miles? Not sure about diff but I think jiffy lube checks that every oil change.
Question relating to audio is if these HU will fit:
http://www.crutchfield.com/p_130X360...H-X3600UI.html
http://www.crutchfield.com/p_130150M...DEH-150MP.html
http://www.crutchfield.com/p_158GT57...P.html?tp=5684
And which one is really worth it more? I like the fact that the more expensive one has a USB spot. Also is there a kit or anything that I would need to buy to fit it? I believe I have the premium infinity sound system since the speakers all say Infinty Gold on them haha.
Also I dont know if my VC is out or if there is a wiring issue? On the current stock HU the screen is supposedly broken but the computer at the bottom in the center dash area and the stock HU screen do not turn on.
Thanks
95GCL is offline
post #2 of 10 Old 10-21-2013, 04:09 PM
PolkaPower
Jesus man, you need to change the trans oil and filter every 30-40 thousand or before with hard use. Same with the diff. Learn to take care of your stuff, don't trust freakin Jiffy Lube to make sure your transportation is working well. Crutchfield tells you if the radio will fit or not and they send all the stuff you need to install it.
PolkaPower is offline
post #3 of 10 Old 10-21-2013, 04:14 PM Thread Starter
95GCL
This isnt my vehicle yet and thats the last mileage I can find SO FAR. I have a ton of papers to go through and am quite busy. I stated that I just got the record, indicating that it was not my car. The PO was my grandmother not me, so do not place criticism on me.
Thats what I thought, however it now says on their site "installation gear for MOST vehicles, for only $15"
95GCL is offline
post #4 of 10 Old 10-21-2013, 04:26 PM
RoldGold
I have this head unit installed in my Jeep GC 96 Limited (very similar to the first one listed by you) http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1. I am very pleased with this radio. I think its wonderful. Screen is a little bit bright and I miss having the display dim with the dash lights, but the audio quality through the USB port is so much better than the tape adapter I was using before. Even with the stock front speakers and some cheap Dual's in the back doors.
You need to use a bezel to have it fit in the opening from the old radio (which is 1.5 dins, and most new radios are 1 or 2 dins. Obviously a 2 din won't fit). I used this one so that way I have a little storage slot: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1. However, mine isn't centered perfectly in the opening, so it looks a little tacky, and its a different finish, but for like $15 I'm happy enough.
I also bought this http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 so I could do the soldering and heat shrink tubing outside the Jeep and not risk getting molten solder on any part of the interior.
I would pull out the radio and see if you have any power coming to the radio, if not check fuses and grounds, etc. I'd think that the HU and the VIC (that's the technical name for the computer below the A/C controls) are on the same fuse, but the electrician for Chrysler must've been on LSD at the time so you'll want to look into what fuses control what.
Oh and I'd recommend you listen to Polka, he knows what he is talking about and I'm sure he wasn't trying to insult you, just get his point across.
1996 Grand Cherokee Limited 4.0L
PSC Steering Gear; NP249 w/ new VC; Moog TRE's, Track Bar, Stabilizer bar bushings and endlinks, control arm bushings
Still no lift, and almost no paint on the hood
RoldGold is offline
post #5 of 10 Old 10-21-2013, 04:29 PM
Kevinyj95
Tranny fluid is atf+4 I would change this and the filter by dropping the pan. The front and rear diff take 80w90. I would change it every 8500m. Yes change them both. Also you need a tune up. You can put any head unit it that will fit. The vic center screen is junk and it wont tell you anything about your vc. There defective. Test your vc by driving in figure 8s slow if the front tires bind or hop your vc is bad, I would change the tcase fluid aswell its atf+4 just like the tranny. Bottom bolt drains the fluid you poor it in the top one until it poors out. yes you have the infinity gold speakers and amp under the rear seat. You will need to attatch two wires together when installing you new HU. Or the speakers wont work. I cant remember off the top of my head which ones. So you will have to look it up. congrats on the new jeep.
Kevinyj95 is offline
post #6 of 10 Old 10-21-2013, 04:32 PM
Kevinyj95
by the way you have a dana 30 front and dana 35 rear and a 46rh transmission and a np 249 transfer case. These are good things to remember in future repairs or trips to the auto parts stores. USB is good for when you download music you can use a 32gb flash drive and keep your entire music collection on it instead of carrying hundreds of cds.
post #7 of 10 Old 10-21-2013, 04:33 PM
RoldGold
It's like the blue/white one and purple one? Something like that. One of them is labeled power antenna on the HU and you connect that to the only remaining wire in the bundle that runs to the underseat amplifier. Google is your friend.
RoldGold is offline
post #8 of 10 Old 10-21-2013, 04:35 PM Thread Starter
95GCL
Thanks for the help from everyone. I believe I have all the info I need now.
95GCL is offline
post #9 of 10 Old 10-21-2013, 04:43 PM
PolkaPower
I just installed a Kenwood from CF a few weeks ago. It came with the bezel, wiring harnesses, and instructions at no extra cost with the radio. There are also a bunch of tutorials on the web.
post #10 of 10 Old 11-17-2013, 12:41 PM Thread Starter
95GCL
Edit:nvm. Might just get some wire connects.
95GCL is offline
