Trailer Wiring Harness Question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Trailer Wiring Harness Question
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 05-17-2015, 07:35 AM   #1
mudhawg93
Is possible on a 98 to wire up a trailer harness without buying a tail light converter kit?
Just got a canoe and kind of need to use a trailer with it lol
98 ZJ Limited 5.2L Quadra-Trac Daily
89 MJ Pioneer 4.0L 4x4 Ranch Truck
93 Mustang LX 2.3L Project
mudhawg93 is offline   Reply With Quote Quick reply to this message
Unread 05-17-2015, 08:08 AM   #2
NTH
Good question. I just got hitch installed and wondering the same.
____________________________
1998 Grand Cherokee Laredo 4x4 // 5.2L // D30/44RE/NP249/D44a //
NTH is offline   Reply With Quote Quick reply to this message
Unread 05-17-2015, 08:29 AM   #3
Cbob4
You need the converter because of the separate brake lights and turn signals on the ZJ...
Cbob4 is offline   Reply With Quote Quick reply to this message
Unread 05-17-2015, 08:55 AM   #4
Taz360ZJ
all ZJ's came with the trailer wiring in the back, all you need is the relay pack and the trailer harness pigtail from a tow package ZJ. literally plug and play with the 7 pin adapter that has the 4 pin capability, and all you need is the extension from the trailer to the 7 pin adapter.
basically, go to the junk yard, find a ZJ with the factory trailer tow harness on the hitch, remove the plug, follow the wiring up the body, there's a rubber plug to seal it. remove the spare tire, remove the panel behind the spare, that's where the trailer wiring lives, the relay pack plugs in to the rectangular black plug below the window, about middle of the way of the glass, it may be tucked up under the metal, it's there just look (unless you have a 1993, some 1993's had trailer wiring on the passenger side about the same location...mid way below the glass, my 1993 has it like that, but my early 1993 i had over a decade ago had it on the driver side like most ZJ's). you might already have the relay pack, you might not. Keep in mind any year ZJ relay pack will work, I have a 1993 and a 1994 relay pack in my 1998 5.9's. i have a 7 pin harness from a 1994 in one 5.9, and i have the 7 plug pin harness in my other 5.9 from another 5.9.
http://www.jeepforum.com/forum/f13/f...wiring-217228/
http://www.northerntool.com/shop/too...3927_200303927
i use that adapter for towing, yeah it's big but it covers just about everything I'd tow, used it to pull my jet ski, enclosed trailers, and a car trailer.
Slate 5.9 Limited 8"/ARB/IRO/KOR/OME/231
White 5.9 Limited stock/231/30's
'93 ZJ SE 5.9 clone
Taz360ZJ is offline   Reply With Quote Quick reply to this message
Unread 05-17-2015, 12:44 PM   #5
kg6mov
Hears the voices
kg6mov's Avatar
A lot of ZJ's aren't tow ready and don't have the wiring for the relay pack. It's common but not universal.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, Backyard parts fodder
kg6mov is offline   Reply With Quote Quick reply to this message
Unread 05-17-2015, 07:09 PM   #6
mudhawg93
10-4 I'll probably just but the converter kit lol
Thanks y'all
Unread 05-17-2015, 07:14 PM   #7
94cherry
1994 ZJ
I have the relay pack, Where do I get the harness that goes from it to the hitch?
Kiss my shiny metal bumper.
94cherry is online now   Reply With Quote Quick reply to this message
Unread 05-17-2015, 07:25 PM   #8
kg6mov
Hears the voices
kg6mov's Avatar
JY is easiest, mopar doesn't sell em anymore AFAIK.
Also note, the relay pack is not the thing in the cubby by the drivers taillight.
Unread 05-18-2015, 10:45 AM   #9
Mel63
I just recently wired mine and this was the best deal I good find, http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
none of the auto parts stores here had one in stock they were special order, I cut the flat four pin connector off and used a six pin round connector and installed it permanently under the bumper, I didn't want to have to drop the wires out the rear hatch door when I wanted to pull a trailer...
Mel63 is offline   Reply With Quote Quick reply to this message
