#1 | |
trailer wire
Where is the t conector to jump in a trlr hitch plug?
My trlr is a 3 wire type ( L, R, and markers ) HOw is it possible to get the jeep's 4 wire to work with the trlr without a converter box? ( my jeep has L, R, Brake, and markers ) Thanks
Lowell 1997 TJ 2.5 to 4.8 Coversion Project 2000 Grand Cherokee WJ v8 4.7 2008 V6 Wrangler unlimited sahara steel blue |
#2 |
You need a converter box to wire in a trailer. You trailer should have 4 wires. which would be left brake/turn, right brake/turn, marker, ground and the colors should be green, yellow, white, and brown.
Just go to autozone or any parts store, maybe even walmart and look up a trailer kit for your vehicle there. Vic
[URL="http://oceanstatejeepsters.com/"]www.oceanstatejeepsters.com[/URL] |
#3 |
You're talking about the same thing; 3 wires + ground = 4 wires
Diagrams for wiring in the factory trailer-tow harness are at wjjeeps.com, for example, http://www.wjjeeps.com/trailer_13.jpg |
#4 |
Doesn't he still need to buy the converter box? That link shows you how to connect a factory type plug and harness.
![]() If your jeep does not have the factory trailer plug, then Hoppy part number 42535 is what you want. You need a converter box because the WJ has separate turn signal and brake lamps. Installation instructions for it are here: http://www.trailerwiring.com/inst/42535.pdf Here's a pic: ![]() Vic
#5 |
Vicypoo is right :
http://www.etrailer.com/pc-VWH~118369.htm His question is how to make it work without a converter box though....since it cost 35 bucks I think you'll find no one has ever bothered to try :P
Nickerdoodle 03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's 35" BFGoodrich KM2 sira4x4.net North East Offroad Club www.carolinadriveline.com www.ironrockoffroad.com kolak@aol.com |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
