Trailer Hitch For 99 WJ Limited Questions - JeepForum.com
post #1 of 8 Old 09-23-2009, 06:49 PM Thread Starter
488TJ
just picked up this 99 Limited with 199k for $4300 and am planning on putting a trailer hitch on it. heard from a few people you had to cut the stock bumper but i dont believe them, was wondering if its true, if so does anyone know of a good brand that u wont have to? i know this is a dumb question but this is probably the nicest vehicle ive owned and id just like to keep it that way...
488TJ is offline
post #2 of 8 Old 09-23-2009, 08:08 PM
xJoshxx
2012 WK
200k miles for 4300 prob should of looked around a little more but still they run for ever
Jeep Grand Cherokee WJ - Trailer towing check this has more info yes u have to Trim the rear bumper to fit a STOCK more form fitting mopar hitch others hang below and are further away from the frame.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #3 of 8 Old 09-23-2009, 08:20 PM
the88thpianoman
2003 WJ
If you take your time and do it carefully, cutting the stock bumper and inserting the bezel to fit a stock trailer hitch will keep your Jeep looking nicer than using an aftermarket hitch that hangs below the bumper. If you look at my build thread (link in my sig), you'll see pictures of both options, as I used to have an aftermarket hitch, but upgraded to a factory setup.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #4 of 8 Old 09-24-2009, 03:50 AM Thread Starter
488TJ
sorry for the typo, its got 119k not 200, thanks for the help ill defly check ur build out
488TJ is offline
post #5 of 8 Old 09-24-2009, 06:46 AM
CanadianZed-J
I've never looked at one, but I've heard that non-tow package bumpers have dotted lines inside to follow when cutting. Would be real easy to make it look decent that way. Of course, to do it properly though you'd want to located one of those black bezels to fit inside the cut to clean it up.
LC.
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
CanadianZed-J is offline
post #6 of 8 Old 09-24-2009, 07:59 AM
Double E
Double E's Avatar
With that mileage correction, that was still a little high for $ but in NH, I imagine that people are willing to pay a bit extra for a year-round vehicle anyway.
It appears that someone also put new headlights in too. Hopefully, it has been well maintained as it appears and you also have good blend doors.
Do the tail lights/brake lights all work?
Any squaking from the door locks actuators?
Check the underside for rust issues on the tranny & oil pan. NE winters are tough on them.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #7 of 8 Old 09-24-2009, 09:14 AM
vosevichs
Everything you need to know.... Jeep Grand Cherokee WJ - Trailer towing
Yes the bezel outline was marked on the inside of my bumper cover.
Scott Vosevich
vosevichs is offline
post #8 of 8 Old 09-24-2009, 05:41 PM Thread Starter
488TJ
no rust, no noises of any sort inside, everything works, and yes the front end does look a little new to me, i think it might of been in a minor front end on the passengers side before but it still rides smooth as hell, i needed a good daily anyways my tj was a hassle to get anywhere
488TJ is offline
Trailer Hitch clemsongt ZJ Grand Cherokee Forum 5 11-06-2008 09:02 AM
trailer hitch inlinegrand6 ZJ Grand Cherokee Forum 3 04-19-2008 06:35 AM
Trailer Hitch VMR ZJ Grand Cherokee Forum 5 10-20-2006 08:55 AM
Questions about a trailer hitch and towing with 2003 Grand Cherokee Overland 500magnum ZJ Grand Cherokee Forum 22 06-11-2006 08:39 AM
