Trailer Brake Wiring - JeepForum.com
post #1 of 2 Old 07-17-2002, 11:03 AM Thread Starter
YBSTUK
i own a '97 Orvis 5.2L. i've heard theres a wire under the dash, that you can connect a trailer brake module to, so you can control a trailer with electric brakes thru the stock trailer wiring. Can anyone help me find this wire under the dash? where's it at? what color is it? is it labeled? Any help would be greatly appreciated. Thank you.
YBSTUK
'95 YJ 4.0L "YBSTUK" - 4.5" Rubicon Express Extreme Duty lift, 1" Body lift, 33" BFG MTKM's on Centerline HT II's, Warn XD9000
'97 XJ Stock (for now)
YBSTUK is offline
post #2 of 2 Old 07-17-2002, 12:17 PM
moabster
moabster's Avatar
2011 WK
My 93 JGC with the towing package had the trailer brake wire. If you call your jeep dealer they can look it up in the shop manual (i had one) and it shows the location. I had to run a wire from the battery thru a circuit breaker and thru the firewall to the brake module which I mounted just to the right of the stearing column. I found the wire that goes to the trailer wiring harness behind a little plastic panel on the side of the jeep (close to where your left foot goes while driving.) It was marked. It was a pretty simple install.
HTH
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
trailer wiring brake light issue MACHJGC ZJ Grand Cherokee Forum 0 04-04-2009 09:51 PM
Trailer Wiring Signals/Brake Do Not Work Jeepshot ZJ Grand Cherokee Forum 4 11-28-2008 09:45 PM
zj oem trailer wiring, no brake lights cnj101 ZJ Grand Cherokee Forum 2 04-24-2006 11:25 PM
Trailer Wiring Fugative ZJ Grand Cherokee Forum 3 03-30-2006 06:26 PM
97 GC trailer hitch brake wiring freddytran ZJ Grand Cherokee Forum 1 05-23-2002 02:13 PM
