trackbar question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > trackbar question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 01-17-2013, 08:50 PM   #1
jasarge
trackbar question
Should the tab that has the nut on it that holds the trackbar to the axle. Should that tab move back and forth when I turn the wheel back and forth??
"I'd rather push my Jeep than drive your Ford"
jasarge is offline   Reply With Quote Quick reply to this message
Unread 01-17-2013, 08:54 PM   #2
riot1987
All of your components in the front should be tight and snug. Nothing should be loose. Have you tried tightening it?
http://www.jeepforum.com/forum/f22/riots-97-grand-1436100/
Build thread^^
riot1987 is online now   Reply With Quote Quick reply to this message
Unread 01-17-2013, 09:21 PM   #3
jasarge
Not yet I was waiting on daylight.. but everything is getting hit with torque wrench in the am
Unread 01-18-2013, 08:59 AM   #4
PolkaPower
The track bar should not move. The tie rods should rotate front to back but not up, down, or side to side.
PolkaPower is offline   Reply With Quote Quick reply to this message
Unread 01-18-2013, 10:45 AM   #5
Uniblurb
Uniblurb's Avatar
In also living in the salt belt I'll bet you won't be able to tighten the TB bolt w/flag nut since it's going to be rusted/seized unless you've had it off before. You'll probably have to remove the bolt to clean the rust off of the threads near the shoulder to tighten it so the nut/TB doesn't move anymore. May take a lot of PB to get the bolt/nut loose and sometimes heat.
And don't destroy the bolt by removing it with tension on the TB. I stripped the threads right off this $20 bolt (96 OE #6502554) then couldn't get the new one in w/o the TB lined up. Some guy named Polka taught me to line up the TB by having someone turn the steering wheel with the front tires on the ground and let the body do the work.
http://www.jeepforum.com/forum/f13/t...-bolt-1367135/
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
-Stalling ZJ? 12 things to check before replacing a sensor; the Dirty Dozen
-Crankshaft position sensor multimeter test. & video of testing.
Uniblurb is online now   Reply With Quote Quick reply to this message
Unread 01-18-2013, 10:54 AM   #6
PolkaPower
I learned that the hard way. Seemed pretty obvious after I realized that's how easy it was lol.
Unread 01-18-2013, 11:02 AM   #7
jasarge
I just had it off when I lifted my zj. But I went out had to replace a few front end parts and it must had worked itself a lil lose. I was able to tighten it up. No more movement!! Thx for all the help..
Sarge
